Surrey/Hampshire Meet
Started by Gaffers, 29 October 2009, 09:48:01
Gaffers
QuoteConfirmed attendees so far:
Guffer
Darth Bog Roll
Pitchfork
Radar
Gaffers
Guffer
Darth Bog Roll
Pitchfork
Radar
Kevin Wood - with Tech2 and genny
Chrisgixer
wahay i can play. :-)
I have some flourescent lights with a cable and 3 pin plug on the end, they plug straight in the wall sockets in the garage. So should be fine with Kevins generator? If i can transport them in the car without braking the tubes? And a basic lead light?
3 ton jack and stands. Air tools and compressor if needed but its not beefy enough for wheel nuts so probably not worth it.
And of course the obligatory halfords pro took kit.
Depends what jobs we are doing i guess. If its all cam belts then wont need all the heavy stuff obviously....?
Yep, fluorescent lighting's good. Not too power hungry.
Never tried running a compressor from the gennie. There's something to try at the weekend. I suspect that'd make it grunt a bit.  ;D
I'm guessing my 1kw spotlights are no good - they alone will make Kevein Wood's genny chug
Xplicit 2.0
gutted that i cant come :( was looking forward to it and sounds like it will be a good meet... maybe next time  :-/
got a 50meter extension lead, if there is a socket in range? Near buy building maybe?
If only I could come :'( :'( :'(
I've got access to a fairly meaty genny too ::) ::) ::)
Gaffers
Quotegot a 50meter extension lead, if there is a socket in range? Near buy building maybe?
Ooooh no, much more than 50m! ;D ;D ;D
Gaffers
Guffer
Darth Bog Roll
Pitchfork
Radar
Chrisgixer
m1ct
Oh i see. ;D
So, who actually needs something fixing or servicing? Of those signed up so far, i cant see an awfull lot of work needs doing?
Who needs a cam belt? Should we have a list of jobs?
LaserLance
id like to come down as i need a door soleniod fixing but not sure on work situation till later in week and i need to get door soliniod unless some like darth has got one lying around ? Also has anyone got a mig welder as me door strap on drivers side has broken away from chassis :-[ :-[
Darth Loo-knee
If anyone wants any parts bringing down let me know :y
Depending on when a few of my own parts are delivered I may have a couple of jobs myself ::)
Gaffers
Quoteid like to come down as i need a door soleniod fixing but not sure on work situation till later in week and i need to get door soliniod unless some like darth has got one lying around ? Also has anyone got a mig welder as me door strap on drivers side has broken away from chassis :-[ :-[
PM me your name and address in case you can make it.  WRT the mig welder I doubt we will be able to run one off a geny, but then I am ready to put right......
Gaffers
Guffer
Darth Bog Roll
Pitchfork
Radar
Chrisgixer
Laserlance
