Surrey/Hampshire Meet
Started by Gaffers, 29 October 2009, 09:48:01
has m1ct pulled out? Or is has she been missed out?
Gaffers
Quotehas m1ct pulled out? Or is has she been missed out?
oops
Confirmed attendees so far:
Guffer
Darth Bog Roll
Pitchfork
Radar
Kevin Wood - with Tech2 and genny
Chrisgixer
m1ct
Laserlance
Gaffers
Can people start adding next their names which jobs they need doing, that way we can get an idea as to how much work is to be done.  At the moment I get the feeling it's not a lot......
Pitchfork
Nothing specific 'cause it's a Traktor but would appreciate it being checked over on KW's Tech 2 and the steering/wheel bearings etc given a look as preventative measures
Quoteid like to come down as i need a door soleniod fixing but not sure on work situation till later in week and i need to get door soliniod unless some like darth has got one lying around ? Also has anyone got a mig welder as me door strap on drivers side has broken away from chassis :-[ :-[
PM me your name and address in case you can make it.  WRT the mig welder I doubt we will be able to run one off a geny, but then I am ready to put right......
Certainly my MIG wouldn't run off a 2kw genny
I have a v6 cambelt locking kit, can swipe tunnies 4 pot locking wedge, obviously tech2 etc. and generaly purpose handtools.
I'm still hoping to make this one :D
Gaffers
QuoteI have a v6 cambelt locking kit, can swipe tunnies 4 pot locking wedge, obviously tech2 etc. and generaly purpose handtools.
Glad to see you've finally put half your hat in the ring! ;D ;D ;D ;D
Guffer
Darth Bog Roll
Pitchfork
Radar
Chrisgixer- cam covers, if there's nout else to do?
m1ct
Laserlance [/quote]
Gaffers
Guffer
Darth Bog Roll
Pitchfork
Radar
Chrisgixer
m1ct
Laserlance
Possibles:
MikeDundee
Radar
QuoteCan people start adding next their names which jobs they need doing, that way we can get an idea as to how much work is to be done.  At the moment I get the feeling it's not a lot......
I have the following that needs to be looked at:
- snapped manifold studs - 2 i think (not sure if the head would have to come off)
- very slight coolant leak - not sure hbv or loose pipe
- droplinks checked
I'm just after a diagnosis first and then hopefully i'll know for sure what actually needs to be done. :y
Well, if everyone's bored with no jobs to do... ;)
Change driver's side central locking motor and fit new speaker.
Investigate creaky rear suspension bushes.
Change spark plugs.
I'm sure I can think of some more... ;)
EDIT: Oh, yes. Investigate why my self levelling HIDs occasionally go into "blind everyone" mode.
Oh, and I might try welding with that gennie if I get a chance in the week. I suspect it'll be a dead loss, and my welding's bad enough with a decent power source. ::)
re welding the door check strap. Does the vx field repair kit cover all eventualitys? I thought it could be fixed with bolts and large washers? Depends how far gone the metal is i suppose?
Quotere welding the door check strap. Does the vx field repair kit cover all eventualitys? I thought it could be fixed with bolts and large washers? Depends how far gone the metal is i suppose?
AIUI, it's the other end - the bracket has come away from the door post on the chassis.
QuoteWell, if everyone's bored with no jobs to do... ;)
Change spark plugs.
Would be interesting to poke about behind your triangular plate, see the orientation and if mv6 bushes are the same as other models. I suppose they will be?
