Done and todo
Started by Martin_1962, 10 June 2007, 22:24:55
Martin_1962
As you lot know I am slowly working through a list of faults and problems.
Did the plenum breather box yesterday and blasted out the breathers with compressed air :-?
It runs better now.
Still need to visit Brackley for the gearbox, and to change that thermostat!
I think I'll do the plugs one evening now I have found my feeler gauges.
Soesn't work and families get in the way ::)
Admin
QuoteAs you lot know I am slowly working through a list of faults and problems.
It runs better now.
Along with it being too warm according to another of your posts!  ;D
The Administrator.
Quote.......
You won't need your feeler gauges, you fit them straight out of the box. Am I correct in saying that a 2.6 uses the same plugs as a 3.2? If so you can't physically gap the 4 electrode plugs anyway.  :y
ians
feeler guages???   :-?  i would just replace them for the cost of the new ones. (and the agro of doing the job on the V6)
Definately replace.
Should come pre-gapped...
Martin_1962
Well I need to check if they are OK first of all - no point replacing if OK
QuoteWell I need to check if they are OK first of all - no point replacing if OK
Martin, as you have it apart, I would replace them. As you have obviously used them enough to think about regapping, they are probably due replacement anyway.  They are £13 + VAT on TC - not really worth the effort not to....
Martin_1962
OK I'm going there tomorrow to get a new glove box lock
QuoteOK I'm going there tomorrow to get a new glove box lock
Presumably you have TC?
Martin_1962
No I haven't so I might call Autovaux
When are you planning on coming up this way, as I may be able to get for you?
Failing that, it would be worth you joining ABS to get your own card ;)
Martin_1962
Later this month or early next month. :y
I know about ABS I keep meaning too ::)
When does Tunnie disappear?
QuoteWhen does Tunnie disappear?
Mid July I think...
Taxi_Driver
Agreed, esp as your lpg.....i use the twin electrode......and change them every 10k on all my lpg cars and never use a feeler guage.....there preset to 1mm iirc.
Think Tunnie is going on his europe travels middle to end of next month  :-/
