Cam Belt Meet - NE Hampshire
Started by Gaffers, 08 December 2010, 10:22:16
QuoteAnyway..... what day is this Meet on?? ;D is it a friday go home saturday or saturday go home sunday???
And what time do the prison doors open??? ;D ;D ;D ;D
You are useless!!!!! ::) ::) ;D ;D
The meet is on the Saturday :y
[edit]Oh... Not that useless... I need your help don't I! :-* :-* :-*[/edit]
Well so you said  ;D ;D ;D
Is there going to be enough tools to enable me to leave mine at home or not?
As my Boyfriend for the night Zok has to shoehorn a bllody boat engine in my car  ;D ;D ;D
Told you the boot would be too small :-X ::) ;D
Not sure TBH... Not going to be bringing much from my tool collection as I can only just lift my top box when healthy!
Darth Loo-knee
I know I know but I just had to have it  ;D ;D ;D  I needed it  ;D ;D ;D ;D
Can't you get Terry to follow you with the tools in his Capri? ;D
I can bring a selection of tools. Having said that I've managed to knacker my back somehow yesterday. It's bloody contagious. I wouldn't mind if I'd actually done anything other than eat a ruddy great roast dinner and sit around. >:(
Darth Loo-knee
#273
Ok some tools will be brought down then.
Next question as I started to lose the will to live reading through this huge thread  ;D ;D   BEER.... are we bringing a load with us? or is it as cheap in this Mess whatever that is as Asda?? ;D ;D ;D
Or as my Boyfriend has suggested Guffer has a Tab  ;D ;D ;D
QuoteOr as my Boyfriend has suggested Guffer has a Tab
Hmmmm.... ::)
(strokes chin ponderously)
perhaps a separate thread for the supplies list for people to put their names
against various group supplies :-/
Less than 3 weeks now! :o 8-)
Gaffers
You can stay the break away from my tab!  >:( >:( >:( ;D
The beer in the bar is very very cheap, typically a pound something for a beer and 60-70p for a shot.   Plus we wont be able to bring in your own stuff to drink
I had a look for my specialist gearbox filling device and it's not in the garage. Then I vaguely remembered lending it to someone - about 2 years ago. ::)
.. so if anyone sees a cheap killaspray in Aldi/Lidl, etc... :y
.. and to remind me more than anything else:
Diff pinion oil seal, if feeling brave, otherwise top up diff oil ;D
Relocate Lambda sensors / try "anti-fouler" solution.
Seth
QuoteI had a look for my specialist gearbox filling device and it's not in the garage. Then I vaguely remembered lending it to someone - about 2 years ago. ::)
I got hold of one of these VERY cheaply a few years back:
http://www.machinemart.co.uk/shop/product/details/26c-paraffin-spray-gun/path/air-line-equipment-air-hose
Never got the chance to try it out though! :D
Fill that up with ATF and I'm going to be out of there! ;D
Should keep Vidal Sassoon in business for a while. :D
I've got one but it's a bit mankey inside... Might have a go at cleaning it out when I get a chance
My last one was about a fiver from Aldi/Lidl, IIRC. Take off the spray lance and replace with a bit of microbore tube with a hook shape at one end and job's a good'un. :y 'til I lent it to someone. ::)
Seth
;D ;D ;D ;D ;D
As it only cost a couple of quid (literally!), my plan was to remove the nozzle, and fit say a metre of flexible tubing in lieu, then suitably reduce the air line pressure.
Would've obviously 'experimented' out in the open by trying it out with a suitable container first!
:D
;D ;D ;D ;D ;D
:D
I have one exactly the same. Whilst it's great for cleaning things, the problem with using it as a gearbox filler will be that the fluid is drawn out of the pot by the air passing through a venturi, so it will always throw out an atomised mixture of fluid and air.
A killaspray, on the other hand, uses air pressure to force fluid out of the reservoir up the lance where it's atomised by the nozzle. Remove the nozzle and they just deliver fluid. ;)
Seth
#283
;D ;D ;D ;D ;D
:D
Point taken Sir .......
When I get a chance, I might just try using the paraffin gun with some Jizer degreasant - and see how it goes!
I'm guessing that it'll be fit for that purpose ;)
Easibleeds work for ATF, but killerspray cheaper
