Cam Belt Meet - NE Hampshire
Started by Gaffers, 08 December 2010, 10:22:16
QuoteChrisgixer.         dif and ATF change.
Entwood ...        ATF change & Tech2 check of gearbox software
Lazydocker...      Oil and filter change, fuel filter, clean ICV, repair wiring to Outside Temp Sensor and (most importantly!) sort sticking handbrake.
TheBoy...           CamCover gaskets (MV6)
Sethsmate ...     Tech2 chat
Jack86...           ATF change and oil and filter, glove box handle and fitting my HID's.
Twiglet...           ATF and Diff oil change, move pre-cat lamdas, resolve mis-fire issue (coil-packs/cam cover gaskets), Tech2 chat.
Taxi Al...             Cambelt, waterpump, breathers, cruise activation. general service bits if time
aaronjb...           Camcover gasket on pass. side & tech2 w/ g/box check/upgrade pretty please
Kieran ....           Cam cover gaskets 2.6, Thermostat housing seal also
Shakeng....         Front/rear bush check(may as well do the rears?)
Kevin Wood...      Dif seal, Relocate Lambda sensors / try "anti-fouler" solution.
Gives
ATF change x4
dif related x3
Lambda related x2.
Cam cover seals x3
Cam belt/water pump x1(only 1?)
Stat housing x1
Handbrake x1
and a bunch of easy service stuff
Tech2 for most I guess? Guess there will be two present?
So, we have one lift and two pits as I understand it? I reckon they should cover the dif ATF and lambda jobs in a day. ATF should be doable in an hour with proper access and pumpy thing.( two gaskets, ATF and clean the filter). The rest there should be time for in other bays at ground level....?  ESP with a Daz bombing round the place.  :y
No suspension stuff so far.  :)
Where's best place to get ATF sumps gaskets?
QuoteCam belt/water pump x1(only 1?)
;D
Unless I'm mistaken, there's only one of each....
Isn't there? :-/
QuoteThe beer in the bar is very very cheap, typically a pound something for a beer and 60-70p for a shot.
Should I be taking Monday off? :-X
;D
Isn't there? :-/
One job/punter/car. Ie nobody else wants a cam belt(and water pump) doing...  ;)
Gives
ATF change x4
dif related x3
Lambda related x2.
Cam cover seals x3
Stat housing x1
Handbrake x1
You're welcome to have a look over mine :y The MOT is due sometime in March so I wouldn't mind getting it up on a ramp to have a quick look over... As for the work on mine... Handbrake and the little bit of wiring repair are most important, very closely followed by the general service items. Unfortunately my back is completely knackered again :'( so I'm going to have to be really careful and probably spend the day as Tea bitch boy/burger flipper ::) So I'll say a big thank you now to the members who have offered to do my work for me :y
Did we get confirmation on it being OK for Tea/Burger?Bacon stuff :-? I could nip to Makro and get a big pack of bacon and rolls if wanted?
I got mine from jpat ... link in the parts section .. :)
We'll sort it LD, TB knows everything about handbrake issues, not a problem.  ;)
You be burger bitch.  ;D  :y
Oh ok, and silkolene Titan 4000? (dex 3)
Do we need a BBQ / gas bottle then ?? Mine is not Bob Dent sized but would be OK for burgers and bangers ??  :)
And a shower cap.
Opie oils ??  also a link in parts ..  :)
QuoteDo we need a BBQ / gas bottle then ?? Mine is not Bob Dent sized but would be OK for burgers and bangers ??  :)
Sure someone had volunteered a griddle :-/
Need confirmation from Guffers that cooking will be OK though :y
QuoteOne job/punter/car. Ie nobody else wants a cam belt(and water pump) doing
I knew that, honest ::)
Sorry Chris, was just being silly. been one of those evenings. ;)
Seriously though, we've a cracking butchers in the village. Can order as required.
Al. :y
Darth Loo-knee
I must admit Entwood I have wondered what we are doing about food too as not read anything  ::)
Or do we need to bring some samo's?
Or is it a guessing game????  ;D ;D ;D ;D
P6UL K
Gives
ATF change x4
dif related x3
Lambda related x2.
Cam cover seals x3
Stat housing x1
Handbrake x1
Hold ya horses!  :D ;D
I need:
Cambelt
Water Pump
Aux Belt
Tech2 check/Cruise activation
I think thats it  ::)
Seth
You might need "Sethsmate's Courier Service" Nige .....
(Car door plus BBQ etc) - just let me know bud! ;)
