Author Topic: MV6 - who says V6 Head Gaskets never fail?!  (Read 18841 times)
« on: 31 May 2009, 00:01:13 »
Baz.... I found the leak mate ;D
I shoud say - I started by stripping out the inlet so I could see the valley. Pressured the system - valley bone dry. No drips from HBV area, all pipework dry - yet coolant was piddling down the passenger side of the bellhousing like niagra falls.
Removed the cat, got a mirror up there, and could clearly see it coming from the rear of the 2-4-6 head gasket...
So the re-build commences! :
« Last Edit: 31 May 2009, 00:01:51 by JamesV6CDX »
Re: MV6 - who says V6 Head Gaskets never fail?!
« Reply #1 on: 31 May 2009, 00:03:50 »
Currently feel like poo, so probably won't get anymore done until next weekend now - apart from maybe some head fettling at home..
« Reply #2 on: 31 May 2009, 00:26:14 »
Needless to say, while it's at this stage, I will be doing both HGs.... crazy not to while 1-3-5 is so accessible.
1-3-5 gasket, was equally as bad - although not leaking externally like 2-4-6.
Thankfully no damage to the heads or the block - no corrosion or pitting to be seen.
I think I may have found a few potentials for the lambda issue too.
Firstly, the "three" earths, on the rear of the 2-4-6 head, had all had their ends cut off, all twisted together, and crimped into one ring connector - so someone has bodged that, for reasons totally unknown! One of them was totally shileded - so not doing it's job at all.
There is a pattern cat on the 1-3-5 bank, and it sounds nasty - free to a good home, if anyone wants it.... it will be replaced with a known good GM item
The O2 sensors don't look geniune - they have the right connectors, however, I can't see any GM markings on them - so this may also be the issue - Omega doesn't like pattern lambdas....
Oh - and someone had put the drivers side camcover gasket on with a pattern gasket, and a load of bathroom sealant  ;D
Goes to show, when there is one issue - best just to do the whole lot in one hit...  :y
markey mark
  • SLady bitshorpe north lincs
« Reply #3 on: 31 May 2009, 00:29:35 »
james if it has had silicone on cam cover whip the sump off and clean the pick up pipe bud !  :y last one i did had loads of silicone in it and a couple of cam cover o rings !!  :o
« Reply #4 on: 31 May 2009, 00:30:29 »
Yep - certainly will do Mate! Going to clean out the bottom of the sump anyhooo...  :y
markey mark
« Reply #5 on: 31 May 2009, 00:31:45 »
happy days ! looks like lack of anti freeze on them gaskets ! i would check oil cooler as well matey ! :y
« Reply #6 on: 31 May 2009, 00:33:38 »
Ho yes - cooler is coming out for inspection and re-seal at min, Markey :y
If it's stainless, and looks OK - any need to replace it?
markey mark
« Reply #7 on: 31 May 2009, 00:35:43 »
oh my days thats a lot of silicone !! naw if its a stainless one it will be fine but separate the cooler from plate and give it a good clean  :y
steverubberduck
  • Kidderminster
  • MV6 BABY!!!!!!!!!!!
« Reply #8 on: 31 May 2009, 09:25:54 »
It's nice to see that the work is being done properly, not cutting any corners like it seems it has been  :y
Keep up the good work  :y
« Last Edit: 31 May 2009, 09:26:23 by steverubberduck75 »
« Reply #9 on: 31 May 2009, 15:48:43 »
I can only imagine that - it wasn't leaking when running - because the head was expanding just enough to stop it.....  it was piddling it out when stopped!
Also surprised at the outcome, because with a HG leak, I'd expect something or nothing, not an "intermittent" leak like this one.
Ah well. Manifolds now removed from heads, I'll start stripping the valves out shortly :)
« Reply #10 on: 31 May 2009, 18:44:27 »
The 2-4-6 head now has all valves and stem seals removed - now for a good clean, and rebuild:
« Reply #11 on: 31 May 2009, 18:57:56 »
With that much silicone I would drop the sump and check the oil pickup is clear. :o
Bear in mind it can kill lambda sensors too.
« Reply #12 on: 31 May 2009, 19:00:58 »
Have you numbered all your valve lifters?  ::)  ::)  ::) ;D  ;D  ;)
« Reply #13 on: 31 May 2009, 19:01:37 »
Yep - I sure will, before it's run again!
If it gets into the combustion chambers?
« Reply #14 on: 31 May 2009, 19:02:11 »
Shaddap you - everything is numbered  ;D  :y
Pages: [1] 2 3 4  All   Go Up
