Author Topic: Toyota Avensis oxygen/lambda sensor help  (Read 3502 times)
joshwyatt
  • Oxford
« on: 08 June 2009, 11:33:37 »
Hello Everyone,
A family member has a 2000 2.0 Avensis estate and the EML light is on, read fault code and is bank 2 sensor 2 fault. I know bank 2 is cylinders 2 and 3, but sensor 2...is that post or pre cat? I'd assume post cat as it's sensor 2 but can't ever assume things. I've been put in charge of fixing it, even though I know nothing about Toyota's and all I know about fixing cars is from the great knowledge from this site. I did suggest he sold it and bought an Omega lol, then I'd have a vague chance of working out how to do things to it. I know this is an Omega forum but don't know who else to ask as someone on here always knows the answer to a question.
Miggy24
  • Exeter,Devon
Re: Toyota Avensis oxygen/lambda sensor help
« Reply #1 on: 09 June 2009, 15:45:58 »
« Reply #2 on: 10 June 2009, 00:53:50 »
i have asked a few non omega car questions on here and nobody minded. They where very helpfull in fact. Not quite as quick coming forward with info but i wider base of experience is needed, esp in your case, so thats not suprising.
I would be assuming the same as you are. But dont know for sure, if the code is obd 2 post it up. Should be able to help as most are communal, some are manufacturer specific. As with most codes ime, its important to establish if the code relates to a fault with the sensor itself or what the sensor is reporting. Or at least bare this in mind.
Link for codes below, there is a toyota link also
http://www.obd-codes.com/trouble_codes/
