Author Topic: The MV6 Engine is...  (Read 3523 times)
« on: 13 June 2009, 23:09:01 »
... finished.  8-) 8-) :)
New stem seals + valve lap, head gaskets, manifold gaskets, camcover gaskets, cambelt, basically top end refurb.
It was all time consuming, held up by silly things like cleaning all the bathroom sealant some monkey had used on the cam covers :( took ages.
Filled up with coolant, pressurised - no leaks  8-)
I couldn't turn the key, as I've not yet got the exhausts attached (awaiting cat) - but it's all gone together slowly and carefully, so I have full faith it will start and be fine.
While I'm waiting, it's now draining all the manky oil out of it - and I will whip off the sump before I start it, just to check the oil pickup for peace of mind  :y
Re: The MV6 Engine is...
« Reply #1 on: 13 June 2009, 23:10:10 »
I will also be replacing these non-gen lambda sensors with some GM ones - I reckon that's why they throw a code now and again - alongside the awful pattern cat, which is being binned in favour of a brand new GM one
« Reply #2 on: 13 June 2009, 23:18:33 »
Should be up for sale in about 5 days then .....   ;D ;D ;D ;D ;D
Good work James  :y :y :y :y :y
« Reply #3 on: 13 June 2009, 23:22:09 »
Nooo - I've still got the rear wheel bearing, ATF Change, full brake service, and MOT to do first ......  ;D
Cheers, Nige  :y
« Reply #4 on: 14 June 2009, 10:59:52 »
Good stuff mate  :y
« Reply #5 on: 14 June 2009, 14:45:21 »
Cheers, Nige  :y
rather right from what I remember ::)
« Reply #6 on: 14 June 2009, 16:59:10 »
Cheers, Nige  :y
Indeed, Mr TB McRae.....  ;D
Dazzler
  • Haverhill, Suffolk
« Reply #7 on: 14 June 2009, 22:54:50 »
and LPG to fit ;)
Then i can buy it ::) :P
Page created in 0.025 seconds with 20 queries.
