Author Topic: need to sort out some exhaust bits  (Read 8672 times)
Plomien
  • Swansea
    • Landrover Freelander TD4
« on: 29 May 2009, 22:58:39 »
I have been quoted £250ish for my exhaust to be repaired.
replacing parts gm176t x2 and gm178p
what are your thoughts on the price is it good or too much?
nick v6
  • walsall / west midlands
Re: need to sort out some exhaust bits
« Reply #1 on: 30 May 2009, 12:05:44 »
you could get stainless steel for around that price
click here
Plomien
  • Swansea
« Reply #2 on: 30 May 2009, 12:32:39 »
none near me :(
nick v6
« Reply #3 on: 30 May 2009, 12:37:41 »
none near me :(
where in swansea are you
post code will be a help :y
Plomien
  • Swansea
« Reply #4 on: 30 May 2009, 12:41:48 »
sa6 nearest is newport
« Last Edit: 30 May 2009, 12:42:08 by Plomien »
nick v6
« Reply #5 on: 30 May 2009, 12:42:34 »
Plomien
  • Swansea
« Reply #6 on: 30 May 2009, 12:44:12 »
cheers Nick will see what they quote me :y
nick v6
« Reply #7 on: 30 May 2009, 12:45:39 »
Unit 14A,
Cwm Du industrial Estate,
Carmarthen
Industrial Estate,
Fforestfach,
Swansea, SA5 8JF
Tel: 02920 861212
i think thats your nearest place
long life exhaust :y
still the same (stainless stell) :y
nick v6
« Reply #8 on: 30 May 2009, 12:46:05 »
no probs mate
glad i can help :y
let me know how you get on :y
« Last Edit: 30 May 2009, 12:46:27 by nickandann »
Plomien
  • Swansea
« Reply #9 on: 30 May 2009, 12:48:57 »
£380 including fitting
nick v6
« Reply #10 on: 30 May 2009, 12:51:01 »
with a lifetime warranty as long as you go back once a year to have the welds checked
not bad if you look at it in the long run :y
Plomien
  • Swansea
« Reply #11 on: 30 May 2009, 12:52:08 »
indeed just need to check my funds to see if I can afford it ;)
nick v6
« Reply #12 on: 30 May 2009, 12:53:21 »
yeah that is the down side :y
jemis
  • Teesside
« Reply #13 on: 31 May 2009, 11:29:15 »
If you shop around a bit more you should be able to get a full system fitted for around £200 but wouldn't expect to get much more than 3 years from it.
You could get the parts and do it yourself for around £130.
« Reply #14 on: 31 May 2009, 18:54:04 »
www.eternalcar.com will do you a complete system for around 120 delivered. As good a quality as you're going to get in a pattern system.
