service light 3.2 V6
Started by SHASSON, 30 June 2009, 20:39:42
SHASSON
Hi , can anyone let me know how to set service light on my 3.2 V6 omega :)
thanks Stephen
..... didn't know we had one ....  well  my 3.2 doesn't !!!
Check the handbook .. (page 12)
http://homepage.ntlworld.com/andrew.reynolds983/Manuals/Omega2002Manual.pdf
and confirm which light is on ... might be the EML which is a very different thing !!
Welung666
Whats the image on the light?
Service light....? Not on an omega old bean. Engine light lit, maybe? Pre cat code?
SHASSON
Hi sorry about service light?
Engine electronics immobilizer ?
Serious or what :-[
Welung666
Click the link below this post and follow the instructions for the pedal trick then post up your results ;) :y
OK .. its the EML  and you have a 3.2 .. so go to this link...
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
and do the PEDAL CHECK ... write down the codes you get and let us know .. we can then advise further
HTH
Welung666
QuoteOK .. its the EML  and you have a 3.2 .. so go to this link...
HTH
Ooooo an echo ;D ;D
[size=20]Echo[/size]        [size=16]Echo[/size]       [size=12]echo[/size]        [size=9]echo[/size]         echo     [size=11] ;D ;D ;D ;D ;D ;D[/size]
Welung666
Quote[size=20]Echo[/size]        [size=16]Echo[/size]       [size=12]echo[/size]        [size=9]echo[/size]         echo     [size=11] ;D ;D ;D ;D ;D ;D[/size]
Welung666
SHASSON
Hi all,
had a blonde hair moment in relaation to electronic immob.
Did the pedal test and hey presto , it worked.
Thanks for all the feedback lads, happpy motoring :) : :) :) :) :) :)
Welung666
QuoteHi all,
So what codes did it give you?
