Author Topic: Need help removing headlight  (Read 2854 times)
Omega man 2
« on: 09 July 2009, 17:01:39 »
Had a look at the guide, but can anyone tell me what I'm looking at in the first pic :(
http://www.omegaowners.com/forum/YaBB.pl?num=1154966960
The one in the guide is a f/l mines a mini f/l should they be the same?
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: Need help removing headlight
« Reply #1 on: 09 July 2009, 17:09:52 »
Looks like the side of the lamp with grill removed mate.
He who brakes Looses
To old to die young
Omega man 2
« Reply #2 on: 09 July 2009, 17:18:48 »
In that case the f/l is different then :-/
Got it off now anyway. Just three screws :y
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #3 on: 10 July 2009, 18:27:35 »
Yes three screws two on top and one low down Which can be fun to get back in  ::) I bet you end up scrabbling under the car trying to find it when it falls off the socket  :D
Omega man 2
« Reply #4 on: 10 July 2009, 18:51:56 »
Yep, done that ;D ;D
Dodger
  • Here in the sunny south!
  • I taught I saw a puddytat!!
« Reply #5 on: 10 July 2009, 22:05:02 »
Try a bit of blu-tak on the head of bolt, before putting socket on. Bolt sticks in socket...easy... when the bolt is done up, just pull the scoket off, and the blu-tak comes away with the socket!! :y
learnt this the hard way, grovveling under the car, looking for the dropped bolt!! ;D
I always knew I'd inherit an estate, but I never thought this would be it!
LFF64
  • HADDENHAM BUCKS
« Reply #6 on: 11 July 2009, 13:12:28 »
Thought you might I have a couple of lost ones down in front of  the car somewhere  ::)
Blutack or even just grease is ok to hold the screw in the socket  :y
amba
  • Medway towns
    • German V6
« Reply #7 on: 11 July 2009, 15:19:34 »
Whole lot easier with the grille by fog light removed..you can then get the bolt in by hand and just use the socket to tighten it up.
