BGA head set
Started by Andy B, 11 July 2009, 13:18:26
Anyone had any dealings with these kits? clicky
Or feel free to suggest another CHEAP/INEXPENSIVE head set.  ;D  ;D
Andy - looks like that HG will be fine and do exactly what it says on the tin
May be better off buying individual gaskets from VX though, if it's a good car?
Just make sure the exhaust manifold gasket is Multi layer steel, otherwise, should be fine  :y
QuoteAndy - looks like that HG will be fine and do exactly what it says on the tin
Just make sure the exhaust manifold gasket is Multi layer steel, otherwise, should be fineĀ  :y
Thanks James. The car is now anything but a good one, it wasn't bad untill No 1 son got hold of it, it only had 74 000 miles on it, but he then ragged the proverbial off it.
Not worth doing more than the minimum to it now, hence looking for a cheap gasket set to make it a runner again for the least financial outlay and then probably get shut of it.  :y
mantagte
have used BGA gaskets a few times never had a problem
in the head gasket sets you get more gaskets than you know what to do with every option is catered for
Quote.......
They can go in a drawer untill I have a clear out in 10 yrs time!  ;)
I'll order it.  :y
