Author Topic: Video of Smokey Astra...  (Read 7053 times)
« on: 19 July 2009, 14:46:01 »
Vid below is of the Astra this morning, after I ran it up to temperature, by Maria's....
Note that this was from warm, not cold.
The problem is actually worse than it's ever been, since I changed all the stem seals....  :-/
http://www.youtube.com/watch?v=MIWFT1NKaOc
Re: Video of Smokey Astra...
« Reply #1 on: 19 July 2009, 15:00:52 »
That's nothing compared to my TD Astra!  ;D  ;D  ;D  ;D
« Reply #2 on: 19 July 2009, 15:29:31 »
Yep, thats a smokie Astra :)
    • E250 Est / Elroq
« Reply #3 on: 19 July 2009, 17:38:07 »
Deffo not right!
could some sensor cause massive overfuelling?  prob very wide of the mark though.
« Reply #4 on: 19 July 2009, 18:32:44 »
Deffo not right!
Considering the amount of oil coming up past the throttle body, probably not  ;D
    • E250 Est / Elroq
« Reply #5 on: 19 July 2009, 18:42:09 »
Deffo not right!
Ill agree to that  ;D ;D ;D
« Reply #6 on: 19 July 2009, 18:43:20 »
Deffo not right!
It's a long shot but the level is slightly over the top mark on the stick - I'm going to drain it out and put correct amount in....
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #7 on: 19 July 2009, 18:53:41 »
Deffo not right!
dont think that would be a prob, mine has been like that for the last 2k.
What coulor are the plugs have you checked?
looks more like the oil rings on your pistons mate. so It looks like your going to have to strip the motor again sorry.
He who brakes Looses
To old to die young
« Reply #8 on: 19 July 2009, 21:17:10 »
Thats a ring.....the head work will have exacerbated the fault
« Reply #9 on: 19 July 2009, 21:23:48 »
Yep, I concluded that since sealing the top end, will have probably made the problem worse!
Interestingly mark, the compression on each pot is well over 18bar, which I think is maybe due to oil? The tops of pistons are all also wet when I take out plugs and shine in torch.
I don't mind removing the head again, but - I'm really not confident with fitting new rings. It's one of those things that, once shown, I'll be able to do endlessly, but I'm worried about breaking it!   :-[
Monza
  • Bungay, Suffolk
« Reply #10 on: 19 July 2009, 21:30:53 »
James, you need to get someone with some Vauxhall experiance to look at that ;D ;D ;D
Past Drives: 16 Monzas, 1 x VW W8 4motion, 1 lotus Carlton, 1 Carlton GSI, 1 Omega Evolution, 1 Vectra 2.5V6, 2 Omega MV6s, 4 Cavaliers plus 131 others over the years!!
« Reply #11 on: 19 July 2009, 21:43:31 »
P!ss off ;D
I plan to re-ring it, I won't be beaten  :y
Ian_D
  • York
« Reply #12 on: 19 July 2009, 22:00:37 »
Forgot how bad 4pots sound!  ;D
[size=12]
« Reply #13 on: 19 July 2009, 23:26:36 »
try it on nicotine gum,it stopped me smoking. :y :D
« Reply #14 on: 19 July 2009, 23:54:41 »
Oil control ring James  :y
Get yourself a piston ring clamp ( http://cgi.ebay.co.uk/Snap-on-Piston-Ring-Clamp_W0QQitemZ110415424035QQcmdZViewItemQQptZUK_Hand_Tools_Equipment?hash=item19b545aa23&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A6%7C72%3A2140%7C293%3A1%7C294%3A25 ) or split an old oil can and use with jubilee clips (don't laugh used this set up to re-ring tuned 2 Lit (overbored) MGB B-series engine!!).
Really easy to fit rings - once you've done a couple James  ;)
« Last Edit: 19 July 2009, 23:55:04 by dbug »
