Video of Smokey Astra...
Started by JamesV6CDX, 19 July 2009, 14:46:01
QuoteOil control ring JamesĀ  :y
Get yourself a piston ring clamp ( http://cgi.ebay.co.uk/Snap-on-Piston-Ring-Clamp_W0QQitemZ110415424035QQcmdZViewItemQQptZUK_Hand_Tools_Equipment?hash=item19b545aa23&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A6%7C72%3A2140%7C293%3A1%7C294%3A25 ) or split an old oil can and use with jubilee clips (don't laugh used this set up to re-ring tuned 2 Lit (overbored) MGB B-series engine!!).
Really easy to fit rings - once you've done a couple JamesĀ  ;)
Thanks for the encouragement mate
It's like everything else
2.0 cambelt kit - scared stiff until I did one - and now done about 20+ for others
Same applies to V6 kit...
Same to head gaskets....
I'm sure once Ive done rings once, it will be a walk in the park second time around...  :y
Bourne
If you decide to go down the route of changing the rings, I'd slip a new set of big end bearings in while it's apart.Won't cost much but will make it more worth the effort. :y
Rings are easy enough to fit......sump off is the hardest part!
What state were the bores in?
QuoteRings are easy enough to fit......sump off is the hardest part!
They actually looked OK Mark - you could see the hone marks on them!
Bent valve
Does it have excess crankcase pressure? what happens if you run it with the oil cap loose/off?
QuoteDoes it have excess crankcase pressure? what happens if you run it with the oil cap loose/off?
Quite a bit of blow back, with cap off...
Bent valve
Unless the breather system is blocked solid, it does sound like worn rings/bores. Easier to do than a v6 top end rebuild though IMHO :y
Pete Elite
 Just a thought James but if it's a Turbo could it be that at sometime the Turbo has gone and filled the exhaust with oil which wasn't cleaned out properly as you seemed pretty sure that it was the stem seals and the bores looked OK :-/.
