Author Topic: Perseverance is...  (Read 4794 times)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
Perseverance is...
« on: 27 July 2009, 19:40:24 »
..spending an hour and a half removing that sodding oil cooler pipe nut from the bottom of the engine, after the first one came out with no fight at all.
 Thought I'd got it once, about an hour ago, but it was in fact me being a twerp and slipping with the socket, only to then damage the nut by keeping turning...
 Bit of filing, some glowering, three cups of tea, and enough swearing to embarrass Ricky Tomlinson... and its out.
 Now just the rest of it to do...  8-)
Re: Perseverance is...
« Reply #1 on: 27 July 2009, 19:44:37 »
Hope it all goes to plan mate  :y :y
Bent valve
« Reply #2 on: 27 July 2009, 19:55:28 »
I always find that swearing helps immenseley :y
 Well done :)
« Reply #3 on: 27 July 2009, 20:10:49 »
I gave up trying to undo the 2nd one and after taking some expert advice I bent it up enough to get the job done.It was a bit nerve wracking though. ::)
« Reply #4 on: 28 July 2009, 12:35:48 »
Bending oil cooler pipes is expert advice?  ::)  ;D
I agree though, as a very last resort, you may have to - better than damaging a thread in the block, 'cos then you're really stuck  :-X
« Reply #5 on: 28 July 2009, 15:14:41 »
 I was considering hacksawing through the pipe and putting a socket around the whole thing, but a quick read on here suggested that would be as good an idea as employing Glitter Babysitting Services Ltd...
 Been out and about, so this afternoon I'm cracking on and will hopefully have it fitted :y
« Reply #6 on: 28 July 2009, 15:37:42 »
Certainly not from an expert!
Ian_D
  • York
« Reply #7 on: 28 July 2009, 19:49:54 »
 Well done :)
It helped me when I changed the steering idler! ;D
Having said that, so did finding a bigger hammer  :D :D
[size=12]
« Reply #8 on: 28 July 2009, 20:46:48 »
desperately wanted to do the job properly when i re sealed my oil cooler plate on previous mig, but really had no choice but to bend them. Those pipe nuts can be real tinkers....
Hope bending them didnt cause the next owner any grief.
« Reply #9 on: 28 July 2009, 22:24:41 »
Get some crows foot spanners - make the job easy!!
« Reply #10 on: 28 July 2009, 22:34:14 »
i am under the impression flair nut spanners will also do the job? Esp ones with a hinge near the head end allowing the handel to angle for access. Anyone have a preference? I guess crows feet are cheaper.
« Reply #11 on: 29 July 2009, 20:54:36 »
SUCCESS!
 Oil cooler fitted, cam cover gaskets fitted, new plugs and filters, fresh oil, everything back together, and it runs better than ever.
 Just got the coolant to flush now, would have had it done if the British Summer weather hadn't intervened with a rainstorm Noah would have been impressed with...
« Reply #12 on: 29 July 2009, 21:28:45 »
Good to hear mate  :y
Mrs. said send some pictures  :D
« Last Edit: 29 July 2009, 21:29:28 by LSG_1 »
« Reply #13 on: 29 July 2009, 21:33:50 »
 Ooh, not at the moment - it's got filth all over it, it looks like an Omega Zebra edition.
 Hoping to have it clayed, polished and waxed by the weekend, I'll photo it then :y
« Reply #14 on: 29 July 2009, 21:34:38 »
Nice one mate  :y
