Author Topic: James engine change got me thinking....  (Read 6169 times)
« on: 31 July 2009, 10:51:11 »
When my 2.2 HG goes, and it will sooner or later. Fitting a 3.2 instead  ::)
Is it just leccy loom and exhaust that would need to be changed? Its already setup for electronic throttle body, so no need to fit cables through.
    • E250 Est / Elroq
Re: James engine change got me thinking....
« Reply #1 on: 31 July 2009, 10:54:27 »
ABS / TC missing on your car for a 3.2
    • E250 Est / Elroq
« Reply #2 on: 31 July 2009, 10:58:27 »
Does it have a beefier gearbox as well...r25 v r28?
« Reply #3 on: 31 July 2009, 11:17:09 »
Would it not be as easy just to buy a 3.2 instead? :-/ :-/
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #4 on: 31 July 2009, 11:40:38 »
I was also thinking of swaping a v6 into my 4 pot. Changing an engine, I thought, was actually quite easy. It just looks alot worse :D
There's a good chance of me getting the engine+gearbox and all "bits" from a 2.5 in the next few months/1 year.
I'd imagine its just a case of loom/heatshields and gearbox.
Not sure about the diff though.
I've had the two cars next to each other and all the stuff is on the four pot for a v6 like the brackets for the exhaust and studs for the heatshields etc.
It shouldn't be much more difficult than just swapping an engine.
Saving for one! All donations welcome, ask for details.
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #5 on: 31 July 2009, 11:41:58 »
Yes it would be cheaper, easier, less hassle and have more sanity. But like I always say , where's the fun in that :D
« Reply #6 on: 31 July 2009, 12:09:47 »
I would need the gearbox too, have to get the engine and box from an x-plod car....
TC? Who needs that?  ;D
« Reply #7 on: 31 July 2009, 12:26:07 »
 ;D but then you're young and limber, Brick - many of us older guys just aren't up to it ::) ::) I speak purely for myself of course ;D ;D
« Reply #8 on: 31 July 2009, 15:35:35 »
that may be 'adjustable' on your existing abs ;)
« Reply #9 on: 31 July 2009, 15:48:46 »
Nah, different setup....the 4 pots have an 8 coil controller, the V6's have a 12 coil controller.
Omegatoy
  • UK
« Reply #10 on: 31 July 2009, 21:32:24 »
not only engine and g.box tho,
what about suspension, brakes diff, propshaft etc etc a lot of work although easy done if you have the bits!! trouble is the four pots do not have the mountings on the body for the twin horse pipes plus the engine moutings are in a different place etc etc :y
« Reply #11 on: 31 July 2009, 21:35:29 »
.. and it will always be a "modified" car and thus a pain to insure, etc. Not worth modifying a car if it's available in the spec you're aiming for.
« Reply #12 on: 31 July 2009, 21:45:50 »
I guess that will apply to my "manual MV6"  :-[
« Reply #13 on: 31 July 2009, 22:00:22 »
Well, yes and no. At least you aren't radically changing its' performance.
« Reply #14 on: 31 July 2009, 22:01:44 »
True.
1 - change it to a manual with DVLA, and hopefully the insurance databases will pick it up as a manual, without further questions asked  :)
