MV6 badges - pictures?
Started by uglymonkey, 21 August 2009, 10:34:05
uglymonkey
Hi ... just popping in quickly to ask for close up pictures of the different styles of MV6 badges fitted on doors/ boots/ trim strips etc
I'm after a set to add to my #cough#ectra ... it's a 3.0 conversion with modified heads and so on, so fancy fitting MV6 badges if they look right.
Am I right in thinking that there's just one style for boot and then the same or bump strip insert style for the doors depending on pre/post facelift? ... or are there others ?(hence asking for pictures!)
Cheers,
James
[movedhere] Omega General Help [move by] Kevin Wood.
daughtert
I am a newbie does anyone have a way to increase miles per tank on a 2.6 auto 02 cdx apart from driving slowly and addiong fuel cleaner to tank to clear injectors etc.
QuoteI am a newbie does anyone have a way to increase miles per tank on a 2.6 auto 02 cdx apart from driving slowly and addiong fuel cleaner to tank to clear injectors etc.
You should really start a new topic, not hijack someone elses!!  You will get a better response.
uglymonkey
Anyone got pics? preface/ facelift ... go on ... just pop outside with your 'phone now and crack a couple off ... :D
cheers
James
QuoteAnyone got pics? preface/ facelift ... go on ... just pop outside with your 'phone now and crack a couple off ... :D
cheers
James
Pre face lift ... & 'miniface lift' (under the skin changes)
and facelift ... looks like an Astra G  ::)
By and large pre facelift go up to V and face lift from V  :y
MickAP
He wanted pics of the MV6 badges.
Mick
QuoteHe wanted pics of the MV6 badges.
Mick
Ah! So you're supposed to read ALL the posts?  ;D ;D ;D
Ooops!
uglymonkey
lol ... brilliant - it's the thought that counts, cheers fella.
still after bigger pictures of the badges ... anyone? trawling through the gallery isn't really bearing much fruit!
cheers
james
