Author Topic: Driveshaft or something else?  (Read 2774 times)
« on: 02 September 2009, 18:04:34 »
My trafic, most times when I turn right, very close or on full lock it clicks does this sound like a driveshaft?
Any idea's?
Re: Driveshaft or something else?
« Reply #1 on: 02 September 2009, 18:19:33 »
Sounds like LSD is slipping. You can get some oil aditives to go in and fix that.
« Reply #2 on: 02 September 2009, 18:58:43 »
Doesn't have an LSD I don't think mate.
unlucky mark mv6
  • tipton,west mids
« Reply #3 on: 02 September 2009, 19:37:33 »
Any idea's?
Cv joint possibly.  :-/
« Reply #4 on: 02 September 2009, 19:57:17 »
Was thinking that too, when turning right it really does click, is that a good indication that it's the right side, also does it need replacement or is it a grease jobby, only does it on full lock.
iainb
  • West Midlands
« Reply #5 on: 02 September 2009, 20:59:05 »
Dry C.V
Maybe split boot.
You will see the leaking grease all over the boot.
« Reply #6 on: 02 September 2009, 21:04:34 »
Dry C.V
Maybe split boot.
Will have a look in the morning, cheers mate  :y
« Reply #7 on: 03 September 2009, 16:02:58 »
Dry C.V
Maybe split boot.
Dry as a bone, no split boot either, did find a split link bar though so that has to be changed, any other idea's as to what the clicking could be?
« Reply #8 on: 04 September 2009, 08:41:05 »
Nackered CV joint, common fault on all Renaults and will need replacing (adding grease will not sort the wear!)
gee-man
  • cambs
« Reply #9 on: 07 September 2009, 21:51:20 »
yea cv joint for sure on that
