Aircon regassed
Started by meegaveesix, 16 June 2007, 12:17:26
meegaveesix
Took the Elite down to Kwik Fit today to get the air con regassed.  Not the first place I would have thought to get it done, but a bloody good deal.
Full regas for £44.95 and if the recharge doesn't drop the coldest temperature by at least 10% then there's no charge.
Rang round locally and prices ranged from £84 from Vauxhall on their "Summer deal"...cheapest I could get was £71 and that wasn't until Monday.  I can't praise Kwik Fit enough, friendly, fast and fitted me in at a moments notice, and I've got a fridge for a car now  :)
driver1
thats a good deal, wish i had gone to kwik fit now, went to a local place here in northampton and it cost me £65 plus vat.  :(
never mind i know next time.  :y
Taxi_Driver
I advised my neighbour not to go to Kwik Fit to have his aircon sorted.....he used a mobile guy i recomended instead.
Trouble is with Kwik Fit , altho a decent price, they dont test for leaks, they dont 'vac' out the system first, they dont add dye with the oil (not even sure they add oil!).
I rang and asked what they did for the £45.......
I hope it hasnt got a leak and stays working for you  :y
Martin_1962
10% - at least 28 degrees drop :o 8-)
Quote10% - at least 28 degrees drop :o 8-)
Eh? yours runing at 280 degrees? Thats what I call global warming...
meegaveesix
QuoteI advised my neighbour not to go to Kwik Fit to have his aircon sorted.....he used a mobile guy i recomended instead.
They vac'd it for 20 minutes before regassing.  I knew it didn't have any leaks, had it checked this morning by my mates garage.  That's why I went budget...I knew all it needed was a regas.  Oh, and they did add oil....they added 950grams of gas and 25 cubic cm of oil.
Martin_1962
Lets say it can get 20 centigrade 10% lower temperature is -9 centigrade.
Eh?
My maths makes it 18C...
Martin_1962
Eh?
20C is 293 absolute so 10% off is 264 absolute which is -9C.
You can't start anywhere but at absolute 0 otherwise it is not correct.
They should have said 2 degrees or something like that rather than leave themselves open to anyone who remembers their O level or A level physics, as I got a good grade at A level.
Eh?
Only engineers work in K, and you cannot call TwitFit engineers. I think they would easily get away with it in court.
Martin_1962
Eh?
And what is wrong with K bring in percentages and you HAVE too - I can't understand  Farenheight though
Quote......
You would if you had a temp of 103 deg F  ;D  :y
Taxi_Driver
Im am suprised, my local kwikfit, said they gassed it, i asked about the the other stuff, they said nope only gass added......but from the sounds of it your kwit fit did a proper job....tho it would have been nice if they had added dye.....in the case of future leaks  :y
Quote......
I had 105 once, apparently at 107 you are dead  :o
Quotei asked about the the other stuff, they said nope only gass added
They hook it up to an automated machine that does everything, which is why they didn't have a clue..
OK if you're sure it only needs a re-gas but hopeless if you've got another problem as where an air con specialist will be able to fault find, Thick Fit will shrug their shoulders and give you a refund. Or in my case, send you packing with no refund and let you extract it from them by snotty letters.
Which Kwik Fit branch was that at, out of interest, meegaveesix?
