bloomin locking wheel nuts
Started by The Red Baron, 28 September 2009, 18:49:02
The Red Baron
that looks a handy piece of kit andy :y
Quotethat looks a handy piece of kit andy :y
ATS used a similar set to remove mine, their's had a finer 'thread'/helix though .... probably best used with a windy gun.  :y
The Red Baron
trouble is, only about 5mm of coller if that to grip on.
Darth Loo-knee
They wil come off with a deep impact socket hammered on them John told you the other day done a number of them now mate :y
The Red Baron
QuoteThey wil come off with a deep impact socket hammered on them John told you the other day done a number of them now mate :y
bugger all to knock on to, also will need a 22/3mm socket then you run out of space between the nut & the hole in the wheel.
serek
Quotevery true, i think i will have to buy some decent drills then give it a go with the torx bit as serek suggests. :y
Buy a cheap Halfrauds set that you don't mind shearing off then, you don't want your best set of 'Draper's' getting damaged ;) ;D ;D
I got set of HILTI  drills use only 4 drills for this job :)
The Red Baron
will give em a go serek :y
Gaffers
If you were closer I could lend you my universal socket.  It will do anything upto 32mm in diameter as long as it is not completely round.  Prob one of my most useful tools  :y
The Red Baron
update....drilled out & knocked a T50 socket into it, promptly twisted the socket. >:(
Welung666
Just keep drilling larger holes till the head comes off, take the wheel off and either weld a nut to the end or get the mole grips on what's left of the stud.
The Red Baron
#25
Quoteupdate....drilled out & knocked a T50 socket into it, promptly twisted the socket. >:(
at last, drilled from both sides to weaken the stud, knocked an even bigger torx bit into it. it came off/out.  :y
however i need a new hub @ £58 >:(
