Pages: 1 [2] 3  All   Go Down
Author Topic: Fancy led tail lights? Me too!  (Read 12987 times)
Re: Fancy led tail lights? Me too!
« Reply #15 on: 21 September 2009, 22:48:01 »
I lot of VAGs have difficult to see indicators, as the brakelights overwhelm them.  How the hell that ever got approved I'll never know
I thought I only noticed this. There are more cars with "invisible" indicators, including japanese cars... and I was thinking the same, how that got approved...
We're obviously not as special as Mr Watt!  :-X
« Last Edit: 21 September 2009, 22:48:14 by Andy_B »
KillerWatt
« Reply #16 on: 22 September 2009, 11:43:17 »
The reason I have never had a problem with them is because I know what they look like when you are anything other than directly behind them and can compensate accordingly.
It's not a special skill, most drivers out there are compensating for something or other every time they get behind the wheel.
Toss & pot spring to mind here Mr watt!  :-X
Oh the irony  ::)
There's plenty I could come back with Andy, and there are no doubt one or two that are waiting with baited breath for me to do it.
However, the fact you felt the need to start throwing direct insults so early on tells me all I need to know.
« Reply #17 on: 22 September 2009, 12:04:44 »
Oh the irony  ::)
Of what!!!  :-?  :-?  :-?  :-?
Go on .... go on ...... go on! Why break the habit of a life time!!!
But you've already proved yourself on many occasions .... keep taking the tablets!
doog
  • Alloa Central Scotland
« Reply #18 on: 22 September 2009, 12:08:13 »
Get off his back man
he has said nothing wrong
looks to me like your spoiling for a fight Andy B
Doug
me at kick boxing
« Reply #19 on: 22 September 2009, 12:13:58 »
Doug
 :-?  :-?   :-?   :-? I merely pointed out his perseved superiority complex in the first place.  3 people comment that VW/VAG led indicator aren't the easiest to see when the car is braking but of course mr Watt could see them perfectly and pointed out the bleeding obvious ie you need to be directly behind them!!!
So .... if you were to turn your attention towards Mr Watt for the fight, he's usually more obliging ...... past posts have frequently shown that!!!!  >:(
mantagte
  • great yarmouth
    • omega bmw maverick
« Reply #20 on: 22 September 2009, 12:20:30 »
Doug
 :y :y :y
KillerWatt
« Reply #21 on: 22 September 2009, 12:30:01 »
My "perceived superiority complex"??
If anybody is perceiving something that isn't there, I'd suggest it was you mate.
You need to read back.
At no point in time did I state that I could see them clearly if I wasn't directly in front of them, I said "Never had a problem seeing/interpreting them"
This was also further clarified by my statement of "I know what they look like when anything other than directly behind them and can compensate accordingly"
Hark, is that the sound of a reversing bleeper I hear?  ;D
Anyway, I have much more pressing things to attend to right now...namely dealing with the pint that has my name on it.
Selseybill
  • La Rochelle
    • 2.0 pre face, 2.2 CDX est
« Reply #22 on: 22 September 2009, 15:11:17 »
if you change to LED bulbs wouldn't the screen in the dash state failure.it did in my old BMW,had to fit resistors
zYx
  • Kent
  • Member of Mayday
    • Black 3.2
    • Grischke Solutions
« Reply #23 on: 22 September 2009, 15:48:47 »
It may it may not.
In my old omega I replaced the headlight with HID conversion kit and nothing came up on the screen.
KillerWatt
« Reply #24 on: 22 September 2009, 17:18:04 »
The "direct replacement" LED lamps already have the necessary loading resistor built in.
nonames
  • Norfolk
« Reply #25 on: 08 October 2009, 14:41:58 »
I was then looking at buying some LED bulbs for my rear brake/tail and front sides
question is would the 360 degree led lights be too bright? or maybe i should get the 5led bulbs?
obv dont want the clusters to be too bright but not too dim either
http://www.autobulbsdirect.co.uk/bulb/bulb_master_3000.php helpful page for omegas bulb upgrades
theres a number of 382 bulbs to choose from, not sure which to get though! any input would be grateful :)
Selseybill
  • La Rochelle
« Reply #26 on: 08 October 2009, 14:50:20 »
Just fitted some red LED bulbs from flee bay.Got my boy to put the brakes on,lovely nice and bright but my bulb failure light on the dash comes on each time i use the brakes.If buying make sure the bulbs have a resistor fitted
nonames
  • Norfolk
« Reply #27 on: 08 October 2009, 14:56:27 »
ive read about that, yup would need the resistor type
does it give a full glow of led? (which is the look im after) rather then actually seeing the led bulb?
deviator
  • Chesterfield
« Reply #28 on: 08 October 2009, 15:09:57 »
These look like Audi/Citroen rear lights. IMHO.
Not a fan, but each to their own.
« Reply #29 on: 08 October 2009, 16:30:12 »
Blimey?  :o Is it time for Christmas lights already?  ;)
Pages: 1 [2] 3  All   Go Up
