Author Topic: Vectra 1.8 X18XE Crank Sensor  (Read 2382 times)
    • E250 Est / Elroq
« on: 05 November 2009, 09:07:04 »
Anyone done a Vectra 1.8 X18XE Crank Sensor
ok or a pig?  doesnt look 'too bad' in TIS, but hard to tell...
Cheers
vxlnut
  • Orkney / Aberdeen
Re: Vectra 1.8 X18XE Crank Sensor
« Reply #1 on: 05 November 2009, 09:59:34 »
I have never done one on a 1.8, but have done them on a 2.0 vectra.  I know on the 2.0 a lot of people re-route the cable because it is awkward to get into the original position.
Depends on how fussy you are really.  I re-routed mine on my old 2.0 and it worked away no probs.
« Reply #2 on: 05 November 2009, 10:26:08 »
Fiddly and dont do it whilst its hot, its un-doing the bolt that is the hardest bit as its obscured by the aircon bracket.
Removing the exhaust heat shield helps you get your hand in.
    • E250 Est / Elroq
« Reply #3 on: 05 November 2009, 10:28:52 »
cheers, tis shows the heatshield removed.
any easier from underneath?
« Reply #4 on: 05 November 2009, 10:34:32 »
Nope, subframe and antiroll bar are in the way
    • E250 Est / Elroq
« Reply #5 on: 05 November 2009, 10:38:28 »
cheers, good starting point then....knowing where to attack from  ;D
