Caravan holiday
Started by familyman, 18 June 2007, 20:52:51
familyman
Well i've done it now. Just got back from our jolly caravan jaunt around cornwall, and the missus and the kids are hooked! Now they want to upgrade  already from our 12 foot to a bigger one. So looks like i may have to upgrade the car as well. I thought my 2.5 auto would handle it easily but after about 60 mph ( i know, i know) the fuel gauge goes down at an alarming rate the temp gauge creeps up to over 105 constantly and the auto box goes spastic changing up to top and lock up and back down again so that it becomes annoying. I was only trying to keep up with a 1.9 tdi auto Galaxy.
Before i left i seviced the car and made dam sure the auto fluid wasn't black and toppped up to correct level at the right temp etc...  but i found when i pulled up at the services for more petrol the cooling fans were flat out and the temp wouldn't come down until i tickled the revs to 2000 then it dropped to normal about 95.  I know the coolants good ( recent heater valve system flush incl. rad.) so any ideas from you OOF guys, would be appreciated. Thinking poss thermostat but normally its okay. Cheers :-X
You came in that, your braver than i thought
Clean the cooling system out with a good flushing agent.....i.e. Forte (not cheap though)
Go to be the best starting point.
Chopsdad
What does your caravan weigh in at?  I pull a 15.5ft with my 2.2, it returns 23mpg and rarely overheats, but it only weighs 850kg unladen.  With a 2.5 I'd have to watch the speedo :-X
Martin_1962
I used to tow with a 2.0 no problems - leave it in sport.
The 2.6 is a good tow car, it will hold top on the level and still gets 16-18mpg or so at motorway speeds, so is not too bad to run (equivalent to a Diesel at 35-40mpg)
No overheating at all
Tony H
Somethings amiss here I tow a boat that weighs well over a ton and have no issues with economy or overheating.You mention frequent gear changes I drive a 2.5 Elite auto that has an adaptive box not sure if yours is the same. No doubt someone will be along soon to advise
A 96 will have old software on the gearbox that isn't the best for towing...
familyman
Cheers all, Leaving in sport mode sounds like an option. Not sure of weight of van but its only a 12 foot early '80s abi monza Aprox 800kg's i've been told. I thought it would be a doddle too so am somewhat suprised. Mpg was about 17-20 mpg on the average as i scare myself on instant mpg!!!!
Probably been asked a load of times The Boy but is it poss. to upgrade sotware, is Trans control in engine ECU or does it have its own module  or is it in the box itself.
Also are the cams prone to wear as i've noticed the engine sounds a bit cammy but not a tappet knock if that makes sense. I fitted a pattern waterpump (a freeby from a friend who used to have a 'meega the same, checked part no. and was correct for my engine) when i done the cambelt and until now has all been okay, but the fact of revving the engine slightly to bring temp down makes me suspect the pump may not be pumping hard enough
QuoteProbably been asked a load of times The Boy but is it poss. to upgrade sotware, is Trans control in engine ECU or does it have its own module  or is it in the box itself.
98 and later only, sorry.
familyman
'sokay mate its not your fault :'(.  Will the later box and wiring fit an earlier car?  Grown a bit attatched to the old girl don't want to chop her in unless i have to. :(
Its the ECU, which is in the car that is flashable, but the flashable ones have a different loom...
familyman
Now we are getting intresting cut and shutting or completely replacing looms, Love those jobs, Car electrics are my fav. No i'm not being sarcy believe it or not.  Will have to look further into this, is the box the same? :y :y :y
The box is the same I believe...
Darth Loo-knee
I have not towed with an Omega yet... but... temperature is surely to rise slightly when pulling a caravan. Omega's (well V6 as far as i know) have oil coolers built into there Rad so thats a thumbs up....
There are a few Guys on here how tow fine so would do like others have suggested.
Otherwise get an old Rangey they Tow Great and get about 18mpg towing or not ;D
Martin_1962
QuoteI have not towed with an Omega yet... but... temperature is surely to rise slightly when pulling a caravan. Omega's (well V6 as far as i know) have oil coolers built into there Rad so thats a thumbs up....
All the autos have coolers
miggy
#14
You should have no problem unless you van is well over the kerb weight of your car, I pull a 5 berth with my 2.2 and never have any issues, fuel or heating.
I used to tow a 4 berth van weighing only 950kg with a 2.0 1995 select auto and the gearbox was always up and down and overheating.
your 2.5 should not have any issues.
