Author Topic: Finally started work on the V6  (Read 6686 times)
« on: 28 November 2009, 19:39:18 »
Without listing everything removed - basically have stripped the top end, down to the stage where the heads are ready to lift. All ancils out the way, it looks very bare!
The only job to do before removing the heads is take off the nearside downpipe.
The Offside one came off fine, but the nuts on the nearside one were totally rounded before I even looked at them :(
I got one of them out with an "irwin" magic socket, but the other one wasn't having it. I need a different size, and it was raining and dark by then, so I called it a day.
Interestingly, you can definately see where it's had a leak, and some sort of additive to treat it. Before I really started stripping, there was an obvious red dye like stain around the drivers side head.
SO - need to get a 13mm irwin socket, and then I can pop the heads off.
In terms of observations
- the cam timing on banks 1-3-5 was spot on. On 2-4-6 bank, about 2mm too advanced. Tension was just below what it should have been, but negligible.
The front vacc tank has had a "mod" at some point, and isn't holding a vacc, so I will pop another one of these on (best to use one from a scuttle of a scrapper)
The sump is definately welded up, so I will have to drill a hole in this, in order to drain it, and then put a new sump on.
Need to get some 2.6 exhaust manifold gaskets, some 3.0 cams, a dremel(!) for porting, and I'll be somewhere near ready to rebuild the heads and put her back together.
At least I've got some done now, the ball is rolling  :y
    • E250 Est / Elroq
Re: Finally started work on the V6
« Reply #1 on: 28 November 2009, 19:41:28 »
Its a start  :y
lpging it?
Ive lost track  :-[
« Reply #2 on: 28 November 2009, 19:42:46 »
Good work  :y
« Reply #3 on: 28 November 2009, 19:42:51 »
I'm itching to LPG it.... but must get the motor A1 first, else there's no point  :y
« Reply #4 on: 28 November 2009, 19:43:18 »
Its a start  :y
lpging it?
Ive lost track  :-[
Hopefully doing his V6 and my 4 pot in the comming weeks  8-)
« Reply #5 on: 28 November 2009, 19:43:49 »
I'd love to know what that red dye-like substance is all around the drivers side head gasket  - K seal or simelar?
    • E250 Est / Elroq
« Reply #6 on: 28 November 2009, 19:54:54 »
isnt kseal normally a goldish residue?  or am i thinking of the slick oil treatments?
« Last Edit: 28 November 2009, 19:55:51 by jimbob »
« Reply #7 on: 28 November 2009, 19:58:48 »
I think you are, Jimbob
I must just say - the cams, shells, and heads, are sqeuaky clean, it's been VERY well serviced despite a pump being used for oil changes...
Martin_1962
« Reply #8 on: 28 November 2009, 20:35:17 »
Aren't they a glass processor? (cuts glass for windows)
Martin_1962
« Reply #9 on: 28 November 2009, 20:36:03 »
Is this a 3.0 or 2.5?
If 2.5 do you have a 3.0 inlet divider yet?
« Reply #10 on: 28 November 2009, 20:37:29 »
Its a 2.5 ....
« Reply #11 on: 28 November 2009, 20:38:22 »
Working on the divider now Martin
If fitting a 3.0 divider, and 3.0 cams - should I also put some 3.0 petrol injectors in (are they greater flow?)
Martin_1962
« Reply #12 on: 28 November 2009, 20:49:24 »
Mine runs fine on 2.6 injectors but the Romano injectors are having trouble
Omegadoha, Desert Member
  • Doha, Qatar
« Reply #13 on: 30 November 2009, 11:01:26 »
Please post some pictures when you get a chance. :y
« Reply #14 on: 30 November 2009, 12:43:09 »
IIRC the injectors are the same.
