03 vectra brake question....
Started by commodore, 08 December 2009, 11:02:39
commodore
changed the front pads on my mates 03 vectra 2.2 elite the other day and re-connected the sensor but the brake warning light is still illuminated....the rear pads are very low also but i was told the rears dont have wear sensors??? does the light need re-setting in some way or is it the rears showing now? many thanks guys.
rustym95
you may of broke the sensor when putting back in pad, dose happen.
unlucky mark mv6
Quotechanged the front pads on my mates 03 vectra 2.2 elite the other day and re-connected the sensor but the brake warning light is still illuminated....the rear pads are very low also but i was told the rears dont have wear sensors??? does the light need re-setting in some way or is it the rears showing now? many thanks guys.
Probably the sensor is not seated right mate,and i have never known them to have rear sensors. :y
Drinky
Rear brakes on Veccy "C" does not have sensors you will have to replace the front sensor as if it has tripped the light it is now U/S even if it looks OK they are only a few pounds from the main Stealers !!!!!!
commodore
Have you still got the old sensor(s)? Chop the (wheel) end off, strip the ends back & connect them together, & refit to the car. If the light goes out, your new sensors are damaged.  :y  :y
