Author Topic: Do headlight bulbs degrade over time?  (Read 5563 times)
Harison213
« on: 23 November 2009, 14:05:33 »
Topic says it all! Do they?
As a side note, I just ordered H1+H7 nightbreakers + sidelights for just over £35 delivered. Sounds good price to me.
mantahatch
Re: Do headlight bulbs degrade over time?
« Reply #1 on: 23 November 2009, 14:12:22 »
The short answer is yes they do. Cannot remember exactly why, but I am sure someone on here will no.
Think it is something to do with metal coming off the prongs and adhearing to the glass, probably not explaine the correctly.
« Last Edit: 23 November 2009, 14:13:59 by mantahatch »
KillerWatt
« Reply #2 on: 23 November 2009, 20:01:06 »
Doesn't matter what use they are intended for, ALL lamps degenerate over time.
Harison213
« Reply #3 on: 23 November 2009, 22:34:14 »
Have been wondering why my headlights are so dim compared to the others around me - still the ones from factory. Nightbreakers on the way though, should get my sunglasses out I guess  ;D
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #4 on: 24 November 2009, 00:11:52 »
Any chance of a link ?, as I may be looking to replace some bulbs myself
davethediver
  • Blackburn, Lancs.
« Reply #5 on: 24 November 2009, 00:13:28 »
Just google Osram Nightbreakers  :y
P.A. Caron de Beaumarchais
Harison213
« Reply #6 on: 24 November 2009, 00:35:39 »
Yep, and the first link is: http://www.autobulbsonline.co.uk/
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #7 on: 24 November 2009, 01:34:53 »
and firefox throws up "Firefox can't find the server at www.autobulbsonline.co.uk"
cruisetopoland
  • UK
« Reply #8 on: 24 November 2009, 07:55:41 »
VERY expensive, that is.
I bought Nightbreakers off ebay from wattbulbs £10.90 delivered per set H1, delivered next day, LED sides are also on ebay-mine were £12 delivered for 10.
DON'T buy Nightbreakers if you can find Philips Xtreme-they are MUCH better, but more expensive-I paid £16.68 (with ebay discount voucher worth £1.53) for the H7 main beams, delivered from aceparts_uk
Wattbulbs also very good when the Nightbreakers filaments dropped out after one week-sent new ones before I sent the old ones back-good seller.
So-buy Philips Xtreme over Nightbreakers-brighter, less patchy light pattern, last longer.
Both wattbulbs and aceparts_uk recommended on ebay.
Can't remeber which seller I got the LEDs from.
Hope this helps  :y
cruisetopoland
  • UK
« Reply #9 on: 24 November 2009, 08:00:04 »
In addition, as per title-the Philips ones last and last and do not degrade, Osrams ok, but fail.
LED sides fail regularly (4-6mths average) but worth the hassle to lose the horrid yellow originals which look even worse next to the whiter upgrade bulbs.
Have used powerbulbs to source bulbs, they are very good but more expensive than wattbulb or aceparts_uk on ebay, both of which are exemplary sellers.
Cheers  :y
Harison213
« Reply #10 on: 24 November 2009, 10:14:01 »
Cheers  :y
Thanks for the recommendation, will use Philips when my nightbreakers fail  ::)
For LEDs, I had them on my motorbike and it failed few times. A mate of mine said you need to put a resistor if using LEDs to limit the current, otherwise they fail quite often. Didn't try it though as I went back to normal bulbs.
cruisetopoland
  • UK
« Reply #11 on: 24 November 2009, 10:46:17 »
Cheers  :y
Mine are cheap Chinese imports, but pretty sure you can buy ones with resistor built in, that are marketed as "no Audi fault code LEDs".  Hmmm  :-/
mathewst
  • Split, Croatia
    • v40
« Reply #12 on: 24 November 2009, 12:17:21 »
I have a question regarding this post
Aren't dipped beams on facelift CD models xenons???
    • E250 Est / Elroq
« Reply #13 on: 24 November 2009, 12:22:07 »
xenons (well HID's) standard on CDX, MV6 & Elite only
mathewst
  • Split, Croatia
    • v40
« Reply #14 on: 24 November 2009, 12:25:12 »
Thanks JimBob.
I guess there were some differences between UK and EU models, cause mine has HIDs' as standard but no sunroof
Page created in 2.191 seconds with 20 queries.
