Author Topic: Which Exhaust?  (Read 7060 times)
Which Exhaust?
« on: 21 December 2009, 14:47:28 »
Tunnie and I bodged mine back together the other night, so its time for a new exhaust on the MV6.
As I see it, options are:
1) Eternalcar with 2yr warranty, about £130
2) Stainless, about £300+
3) Genuine GM, about £320
Up until recently, it would have been GM, but quality on those isn't great now.
Car is nearly 12yrs old, 160k on clock.
Discuss :)
Re: Which Exhaust?
« Reply #1 on: 21 December 2009, 14:54:28 »
Eternalcar every time. Not that different in quality to genuine, and cheep.
Or.. If you know you're keeping the car long enough to get your money's worth, and don't mind a bit more noise, stainless.
Re: Which Exhaust?
« Reply #2 on: 21 December 2009, 14:55:23 »
.. or get out that shiny new welder and bodge it some more. :y
Re: Which Exhaust?
« Reply #3 on: 21 December 2009, 14:55:44 »
Comparing the qauility between mine and father tunnies, GM has dropped a lot, that was back in 2007.....
Given its age and miles, and your tastes, i don't think stainless is the route for you, go Eternalcar and put money saved into fart gas conversion
Re: Which Exhaust?
« Reply #4 on: 21 December 2009, 14:56:18 »
He burn't a big hole in it last time  :-X  ::)
Re: Which Exhaust?
« Reply #5 on: 21 December 2009, 15:22:26 »
Going by last weeks efforts, I'll use the old exhaust for practicing  :-[
In my defence, when welding, it helps if there is something metalic to weld to!
The bolts holding to the cat section look a bit nasty as well... ...better get some new drill bits methinks
Re: Which Exhaust?
« Reply #6 on: 21 December 2009, 15:23:34 »
Realistically, I will be able to buy 3 lots of eternal and still come in under stainless cost. Which, considing cars age......
Noise is my biggest concern.
Re: Which Exhaust?
« Reply #7 on: 21 December 2009, 17:07:11 »
That was my concern. Stainless probably not the best option then. My Eternal exhaust is a little noisier than the main dealer one Chrisgixer has fitted, but not to the tune of nearly 200 quid.
Omega3
  • Hertfordshire
Re: Which Exhaust?
« Reply #8 on: 21 December 2009, 18:26:05 »
recently had to replace cat back on my 2.2 to get through mot. Had no time to get eternalcar so had walkers centres and GM rear box fitted. dissappointingly centres much noiser than blowing original pipes so ordered eternalcar centres and just had fitted. (sold walkers bits locally) still not as quiet as original particularly around 60-80mph. Think I'll need to do the 3.2 soon, still hanging on with the original system after 7 years. Bit reluctant to fit eternalcar as noise on 2.2 changes whole character of car. Local stealer says quality of replacement system should be same as original....
Previously: Mercedes CLK 320cdi, Insignia SRi, 53 Omega 2.2CD, 02 3.2 elite, 01 Omega 2.2CD, 94 Omega 2.0 Est, Mercedes 300TE, Toyota Supra 3.0, Honda Legend Coupe, Supra 2.8i Mk2, Fiat X1/9, Lancia Trevi
Re: Which Exhaust?
« Reply #9 on: 21 December 2009, 18:41:45 »
About 2yrs ago, the quality fell off a cliff, but price went up.
Re: Which Exhaust?
« Reply #10 on: 22 December 2009, 04:00:48 »
i'm with Kevin, esp with the your miles. :-)
Edit.
At any miles actually. Should have fitted one myself at 80k and saved myself 180 notes. If i'd known at the time of course. Always easy to be wise after the event.
« Last Edit: 22 December 2009, 04:22:34 by chrisgixer »
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
« Last Edit: 22 December 2009, 16:31:26 by iggy21uk »
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
mrjimbo
  • Oxfordshire
Re: Which Exhaust?
« Reply #12 on: 22 December 2009, 17:36:04 »
I got one from here and fitted well and still going strong after 18 months came in at just over £100 for 2 centre sections and a back box for an estate, but gone up a little since. There in Blisworth, Northampton so not far away if you want to collect   :y
     http://www.onlineautomotive.co.uk/Default.aspx
Re: Which Exhaust?
« Reply #13 on: 22 December 2009, 18:37:04 »
GM cheaper. They ar having a laugh.
Markjay
  • London
Re: Which Exhaust?
« Reply #14 on: 22 December 2009, 21:05:32 »
My first Omega was sold at 4 years old and the second Omega at 6 1/2 years old, both with original GM exhaust. I must say though that on the first omega I had an advisory for the back box on the last MOT before selling the car. But then if you say the quality is no longer what is used to be....
Alas, no more Omegas....
