Author Topic: american omega equivilent?  (Read 5345 times)
lozzy
  • Irmscher UK Sales and Support
« on: 22 December 2009, 12:08:54 »
hi guys whats the american version of the omega called ?
or what american GM cars use the same engine as the 2.5?
cheers
1 Omega Estate 100 speakers :D
    • E250 Est / Elroq
Re: american omega equivilent?
« Reply #1 on: 22 December 2009, 12:10:09 »
Its the Catera  :y
lozzy
« Reply #2 on: 22 December 2009, 12:17:29 »
awesum now to see if i can hunt down a massive alternator for my mig i assume the wiring the same ?
    • E250 Est / Elroq
« Reply #3 on: 22 December 2009, 12:20:15 »
Dont know the exact details on engines and wiring.
They certainly have different dashboards, and different ECU's as they are limited iirc.
« Reply #4 on: 22 December 2009, 12:21:11 »
what makes you think american alternators are more powerful?
Souce an ex-plod one from the UK, they have beefier ones than standard
lozzy
« Reply #5 on: 22 December 2009, 12:24:28 »
there are lot more aftermarket high output alternator builders and when you enquire they have never heard of an omega but will more than likely have a listing for a catera or can build one for me
« Reply #6 on: 22 December 2009, 12:42:27 »
mention the 3.0, not sure if the 2.5 was sold in the Cadillac Catera
lozzy
« Reply #7 on: 22 December 2009, 12:47:18 »
yea doesnt seem they do the 2.5 only 3.0 block id assume the mountings are the same ?
Markjay
  • London
« Reply #8 on: 22 December 2009, 21:08:30 »
Variations of the same V6 engine (sometimes with increased capacity) were (and I think still are) available on other Cadillac models.
Alas, no more Omegas....
lozzy
« Reply #9 on: 30 December 2009, 09:51:20 »
well just a quick update on this for people who may want a bigger alternator i hopefully may well of sourced a bolt on 250a alternator from the catera bags  of juice !! ;D
I_want_an_Omega
« Reply #10 on: 30 December 2009, 10:53:00 »
I was going to ask why - but see from pics that its for audio?
lozzy
« Reply #11 on: 30 December 2009, 11:28:58 »
yea its for my new system thats being built in an omega estate the standard 120amp alternator wouldnt cut the mustuard to charge the batterys  :o
I_want_an_Omega
« Reply #12 on: 30 December 2009, 11:38:29 »
So, 120 amps x 12volts = 1440 watts of input power,and 250 amps is 3kw !
I take it you wont be driving when this "device" is in full swing  ::)
lozzy
« Reply #13 on: 30 December 2009, 11:50:48 »
no way would be too difficult to drive with an alternator that big on load will put quite a strain on the engine and also the volume output can make things diffidult to see
the voltage on the regualtor will be set at 15 volts :)
goonv6
« Reply #14 on: 30 December 2009, 12:25:43 »
I wish I'd seen this earlier, you can have your current one rewound to whatever spec you like but I also have a 250amp one sitting in my garage from my Chevy v8 you could have had for £50. You just need to switch over the pulley on it.
