broke down td
Started by raywilb, 02 February 2010, 19:33:30
raywilb
i ended up being brought home coutesy of the AA today. pc test indicates 44 incorrect boost pressure, & 82 sensor injector start incorrect rpm signal. can anyone let me know what these mean & how to put things right.  :'( :)
hoofing it
#1
44 is the turbo this won't stop the engine running.
82 is injector number 4 the one with the wire this will not let the enginge run if knackerd.
make sure the plug is in ok below the manifold
or look for a broken wire on the injector.
is the managment light going out :question
Ddraigcymro
82? wont let engine run if nakerd?
Only reson im asking as I got code 82 on 2.5td but now flead fuel and cleand most of the crap out it runs, will ad though it cuts out while driving take foot off ecelarator and back on and she drives away as though nothing hapend.
I don't suffer from insanity, I enjoy every minute of it.
raywilb
update. put fully charged battery on. 10secs of turning key it started though it spluttered a bit (never konked out though) i did tighten feed pipe from lift pump at least 2 complete turns just before attempting to start. could an air lock cause code 82. i,m baffled.  :-/ :y
Ddraigcymro
