Author Topic: 6 coil packs in less than two weeks  (Read 1647 times)
david_omega
« on: 11 February 2010, 23:49:29 »
in under 2 weeks, i have had to order 6 coil packs, some from oil damage, mainly 4 right bank ones for the water problem. what a coinsidence tho, never done one before, then get 4 troubled motors in the same fortnight. oh well. part and parcell of age related issues i guess!
Re: 6 coil packs in less than two weeks
« Reply #1 on: 12 February 2010, 00:02:14 »
Something to do with the cold and snow perhaps ???  Cold causing the windscreen/scuttle seals to shrink and the snow/ rain getting through the gaps ??
Just a thought ???
« Reply #2 on: 12 February 2010, 08:41:31 »
I must update the cam cover maintenanc guide.....adding a run of the sealent along 2 bits of the plastic camcover should help this a lot
    • 530D M Sport, 330i Coupe
« Reply #3 on: 12 February 2010, 09:26:21 »
Yep, that's what Geoff & Pete told me they started to do at the factory after discovering the problem.
« Last Edit: 12 February 2010, 09:26:42 by VXL_V6 »
ians
  • Reading
« Reply #4 on: 12 February 2010, 13:37:41 »
don't you mean scuttle?
my problem is leaking through the wiper hole..
« Reply #5 on: 12 February 2010, 13:39:44 »
I am sure it is but.....there is a trick you can do when changing the cam covers to stop the water getting into the plug wells.  :y
Page created in 0.011 seconds with 15 queries.
