Pages: [1] 2 3  All   Go Down
Author Topic: LPG Kit Supplier and some thoughts...  (Read 8563 times)
« on: 15 February 2010, 13:34:30 »
 I have spoken to the supplier today and expressed some concerns with respect to his answering service as several people, myself included, have had issues getting in contact. The good news is that he has hopefully settled down a bit now and shouldn't be travelling as much :y :y
He's also developed a new ECU, with some interesting features including a "self-learn" function, which does exactly that... You calibrate it and set it to self-learn and it does the full calibration whilst being driven about, without the need for a laptop connected and someone keeping an eye on it :y :y
Now for the interesting part... I'm looking at options for Toroidal tanks for the Estate I'm after and was struggling to see more than a 55L tank fitting, which included raising the floor about an inch. This simply wouldn't be big enough for my requirements (in reality) as that's only a 44L usable size and 10ish Gallons at an average 20mpg (worst case average) isn't enough, never mind when the Caravan is on the back :o :o
The suggestion, which is something he has done numerous times, is to cut out the bottom of the wheel well and use a top mounted tank attached to a steel plate which is, in turn, fitted to the boot floor over the wheel well.  :-/ :-/
Now this has some real potential... It means the floor doesn't need raising any noticeable amount (2.5-3mm for the plate) and, I think, a 77L tank... Which is much more reasonable, giving about 61L usable, only 3 L less than Kevin Woods' and Entwood's tanks. This makes it workable :y :y
My thinking is that it has real potential... Whilst I'm not overly happy about cutting a great hole in the floor of a new car, it does mean getting a reasonable sized tank in. As long as it's finished properly and sealed correctly it's fine :y :y
So... Any thoughts?
Re: LPG Kit Supplier and some thoughts...
« Reply #1 on: 15 February 2010, 14:00:31 »
I've been looking at the mapping software for that new LPG controller and would be keen to play with one if anyone is tempted and about to convert. In addition to self-mapping it has much more flexibility for manual mapping.
I believe the self-mapping requires an OBDII complaint engine ECU though. :-/
As to the spare wheel well option yes, it would be interesting to try. Firstly, you could use a centre-filled toroidal tank as you wouldn't need the valve to be in the centre. It could be on the edge of the tank and, since it'll be dangling in fresh air you won't need any ducting for ventilation.
The petrol tank on the estate is fairly closely moulded to the shape of the wheel well as we discovered when doing Marie's install. Not having the wheel well in place will increase the volume available quite a bit, but fitting it within the confines of the petrol tank will be the ultimate limitation. I guess the petrol tank could be dropped a few inches by spacing out the tank strap mountings for a bit more space.
It's a nice idea. It would be great to chop out the wheel well on a car, weld in a flat floor and then take it along to Teilo's to offer up some tanks and see what the limits are.
Now, where's that tin opener...  ;D
« Reply #2 on: 15 February 2010, 14:06:39 »
I need to get my ass in gear and covert mine, all the required stuff is in the garage  ::)
Got half of March off (18th to 2nd April)
If your free then be good to get mine converted  :y
« Reply #3 on: 15 February 2010, 14:08:33 »
The new ECU isn't the Stag 300-Premium/Plus... It's his own design, manufactured in the UK, although he is expecting some Premium/Plus ECU's through soon.
The Self Mapping on his ECU isn't OBD2 dependant as the ECU isn't OBD2 ;) ;)
So... The tank is moulded around the wheel well? And under or just around?? If it runs under that may pretty much scupper the idea of cutting out the floor, although it will offer extra weather protection ::) ::) ;D ;D
The plan is to use a Top mounted, Full Toroidal Tank, which I think I could get a 77L one in, assuming there is space under the car for the correct ground clearance. I said about welding the plate in and he said it's not essential... Can just be bolted in :-/ :-/ Think I'd prefer it welded, with a small access panel to get to valves/wiring
« Reply #4 on: 15 February 2010, 14:10:09 »
You've not got a Stag 300 Premium/Plus controller though ::) ::)
I did say that I'm available at odd times, working 4-on/4-off... Just give me a shout and I'll see if I can help :y :y
« Reply #5 on: 15 February 2010, 14:12:15 »
D'oh, your mappings with be for 6 pots of course  ::)
Cheers mate, may very well take you up on that. Got a spare inlet manifold thanks to KenT which i need to get the LPG injectors mounted on first  :)
« Reply #6 on: 15 February 2010, 14:15:23 »
If the tank is around and not "under" the well... What's the dimension of the "hole" in the tank... I've based the thoughts on a 650mm diameter tank... If I can go up to 720mm Diameter then can get a 95L one in there ::) ::)
« Reply #7 on: 15 February 2010, 14:16:52 »
There's an expert at fitting nozzles on here... In fact, he's posted on this thread above your first post  :-X :-X :-X ::) ::) ::)
« Reply #8 on: 15 February 2010, 14:18:27 »
He's got too much else on  :-X
« Reply #9 on: 15 February 2010, 14:19:44 »
Assuming you're converting, can I come and help / take the piss?
« Reply #10 on: 15 February 2010, 14:21:28 »
Noted  :y
I'd like to help as much as i can, Kevin Wood kindly offered to do them if i post them down, but i feel bad doing that. I want to try and do as much of it myself, Suffolk is a bit far for me  :'(
« Reply #11 on: 15 February 2010, 14:21:59 »
At me or TB? Think all the 2/3's engine jokes have run their course  ::)  ;D
« Reply #12 on: 15 February 2010, 14:23:58 »
Oh dear... Looks like Tunnie's going to have to go and have buy a pig for all those Bacon Sarnies ::) ;D
« Reply #13 on: 15 February 2010, 14:25:25 »
No doubt my garage with its 'boys tools' will be called apon  ;D
« Reply #14 on: 15 February 2010, 14:25:46 »
Noted  :y
I meant Kevin... He doesn't mind, it gives him something to do while SWMBO is watching the soaps ;D ;D
I was offering to come over that way to help you out... You've got a garage ;) ;)
Pages: [1] 2 3  All   Go Up
