Author Topic: Look where this says the keys can be reprogrammed.  (Read 2570 times)
Hannah Judes Dad
    • the misses round the bend
mantahatch
Re: Look where this says the keys can be reprogrammed.
« Reply #1 on: 22 February 2010, 15:13:59 »
The transponder part of the key can be programmed at a locksmith. I have seen it done, takes about 10 seconds. As all they do is copy the signal from the original key.
Programming the remote bit I believe needs tech 2.  :y
Hannah Judes Dad
« Reply #2 on: 22 February 2010, 15:31:17 »
It's the second remote that needs programming.(Had to re-read the advert)  :y
ScottieMV6
  • Swinton, Manchester
« Reply #3 on: 22 February 2010, 16:52:27 »
It also says that you can have the climate "ice cold on one side of the car and red hot on the other". The owners manual says you shouldn't have them set more than 2 degrees apart :-? :-?
I'd rather be scared to death than bored to death!!
hoofing it
« Reply #4 on: 22 February 2010, 18:53:37 »
This is the second time listing for this.
personaly I wouldn't touch it
oceansoul
  • Sunbury on Thames - Surrey
« Reply #5 on: 23 February 2010, 20:35:14 »
You can do it. Just all mixes up in the cabin and doesnt really work well :p
Psychoca
  • Norfolk
    • Beaten up Mondeo TDCI ST.
« Reply #6 on: 24 February 2010, 11:28:48 »
I like the bit that says the car will do 40+ mpg...  noticing the car is probably not chipped...
Hannah Judes Dad
« Reply #7 on: 24 February 2010, 12:35:49 »
£1080 and reserve not met  ;D ;D ;D dream on
