Poor performance
Started by Matchless, 22 June 2007, 23:06:24
Matchless
Anyone suffering from poor performance from a V6 following a cambelt tensioner failure or after finding that the cam timing was 2 teeth out?
I think i have got to the bottom of why my project car is so slow, and its not just because the previous car was a 3.0.
If this has been seen by others I will write up a diagnostic how-to but its a bit long winded as its a case of eliminate every possibility and what you are left with means an oily weekend.
Ronald_McBurger
Just a wild stab in the dark, but maybe the balves on the passenger side bank may be slightly out - maybe 2 thou or so, thus a drop in compressiona dn a wildly varying vacuum? Probably just wants some new valves. Am I close? ;)
Admin
#2
Now either that is a piece of deduction that would be impressive by even Marks standards.... or you 2 have been chatting!
I wonder which it is .... ;D
Oh and you want to pick up your voicemail!  ::)
The Administrator.
My 3.0 has had poor performance before and after a cambelt change and the original belt was out on the left bank of cylinders but when I replaced the belt I am pretty sure I got it right.
Matchless
QuoteMy 3.0 has had poor performance before and after a cambelt change and the original belt was out on the left bank of cylinders but when I replaced the belt I am pretty sure I got it right.
Can you do a vaccuum check, record the value at idle, then open the rear multi ram by hand and see if the vacuum changes.
QuoteCan you do a vaccuum check, record the value at idle, then open the rear multi ram by hand and see if the vacuum changes.
I think I can see where you're coming from here.  :'(
STMO123
QuoteJust a wild stab in the dark, but maybe the balves on the passenger side bank may be slightly out - maybe 2 thou or so, thus a drop in compressiona dn a wildly varying vacuum? Probably just wants some new valves. Am I close? ;)
There's a couple of heads, with nice clean valves etc, on ebay at the moment
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ih=018&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=280126541323&rd=1&rd=1
I wouldn't have a clue how to test the vacuum tbh :(.
Matchless
Have to wait till the next meet then.
Thats not a problem the old girl can still pick her skirt up if she has too, its the fuel economy or lack of it thats the problem ::)
Are you still down in Slough, Pete?
I've got a vacuum gauge if you want to give it a try.
QuoteAre you still down in Slough, Pete?
Hi Kevin
I finished in Slough last week but thanks for the offer :y
