Author Topic: Painting  (Read 4456 times)
Painting
« on: 11 March 2010, 22:09:52 »
Well the bloke who mucked my van up sorted front & rear bumpers and bumper inserts, but to any painters on here, what special primer will he need to paint the plastic door mouldings and any idea how they are stuck on, on an Astra H, also can he paint them on the van without getting paint in the gaps like he did last time. Been a long time since I did any car painting so help will be appreciated  :y :y
« Last Edit: 11 March 2010, 22:10:28 by LSG_1 »
Re: Painting
« Reply #1 on: 11 March 2010, 22:13:19 »
I think the primer needs to have plasticiser in it Del, so the paint can flex rather than crack when the plastic expands/contracts depending on temperature.
Re: Painting
« Reply #2 on: 11 March 2010, 22:32:08 »
Cheers mate, I'll make sure he uses it, he's begining to annoy me now a bit, pay for a job and it's been in 3 times now  >:( People were supposed to be coming to view this week too  >:(
unlucky mark mv6
  • tipton,west mids
Re: Painting
« Reply #3 on: 12 March 2010, 16:18:29 »
If your painting bear plastic,its just normal plastic primer you need,and if its already painted,theres no need to prime,just wet sand to a nice finish,and put paint on top plus laquer. :y
Re: Painting
« Reply #4 on: 12 March 2010, 16:31:02 »
Not already painted as when I took it to a jet wash to prove how shit the finish was, it blew all the paint off. I'd put money on it that he never primed it before to be honest. Cheers Mark and Albs by the way  :y
unlucky mark mv6
  • tipton,west mids
Re: Painting
« Reply #5 on: 12 March 2010, 16:34:00 »
spacekid2009
Re: Painting
« Reply #6 on: 12 March 2010, 17:31:41 »
Del, there's acouple of reasons for the paint to flake off, as with most things, preperation is everything, he needs to key the surface with a fine grade scotch pad, and before applying any primer or paint, he needs to spray the surface with plastic adhesion promoter, otherwise nothing will stick, if it's a black textured finnish at present, and you want a smooth finnish, he needs to spray the complete part with high build primer to cover the textured surface, then apply base coat and clear coat, hope it works out for you, any problems, send me a message, good luck.
Re: Painting
« Reply #7 on: 12 March 2010, 18:10:42 »
Thanks for that mate, just what I was looking for  :y
spacekid2009
Re: Painting
« Reply #8 on: 12 March 2010, 18:43:58 »
You're very wecome, hope it goes ok for you, i live too far away or i'd come and do it for you, good luck with it.
Re: Painting
« Reply #9 on: 12 March 2010, 18:58:49 »
It's very hard to find a good painter down here to be honest mate, all of them seem to be cowboys who do a crap job or get the wrong colour. Would be nice to have someone such as yourself near here don't fancy moving do you  ;D Very much appreciated though  :y
Re: Painting
« Reply #10 on: 12 March 2010, 20:04:09 »
Could he paint them (door mouldings) on the van, last time he did it it left paint in the gaps, will he have to take them off?
Cheers again mate
spacekid2009
Re: Painting
« Reply #11 on: 12 March 2010, 20:20:41 »
Ideally you'd want to take them off, but anyone whos decent at masking shouldn't get paint in the gaps, i always have a filler spreader split down the center to push excess tape neatly into any gaps, and also, de mask when the clear coat is still wet, this will prevent him peeling off the new paint when it's all baked off and dry, colour coding mouldings really isn't that difficult, but i suppose you get good and bad in every trade.
Re: Painting
« Reply #12 on: 12 March 2010, 20:23:08 »
Thanks for that mate  :y :y :y
One last Q, can you take them off without bending them up, any tricks to taking them off?
« Last Edit: 12 March 2010, 20:24:28 by LSG_1 »
STMO999
Re: Painting
« Reply #13 on: 12 March 2010, 20:27:07 »
This painter's gonna love you. ;D
Re: Painting
« Reply #14 on: 12 March 2010, 20:29:14 »
The one on here or the one doing the van?
The one on here has been more than helpful, the one doing the van won't be getting my custom again  >:(
