Pages: 1 [2] 3  All   Go Down
Author Topic: Insignia washer jets  (Read 6766 times)
Welung666
Re: Insignia washer jets
« Reply #15 on: 16 March 2010, 14:29:07 »
Do you have a part number and rough cost for a pair Mark?
I'll pick a set up and see about doing a HowTo including fitting the heaters.
« Last Edit: 16 March 2010, 14:29:51 by Welung666 »
« Reply #16 on: 16 March 2010, 14:51:27 »
Part numbers are:
12782509
12782508
Retail is 1.89 each plus vat.
You need one of each.
The heater would require a resistor epoxying into the base of the jet (there is a recess)
« Reply #17 on: 16 March 2010, 14:59:27 »
does insignia have no screen wash heaters at all?if not, might imply gm dont think they are necessary if washers are in that scuttle location.??
and yes agree re cheap screen wash ill ask the q on another thread when i've checked the make.
« Reply #18 on: 16 March 2010, 15:00:28 »
I checked and no heated option for the insignia....
Easy enough to sort though
« Reply #19 on: 16 March 2010, 15:08:39 »
thats great, off to the dealers :y :y :y
Andyb
  • Lincoln
« Reply #20 on: 16 March 2010, 16:46:32 »
Any thing else that would fit ?????????
has anyone got any ideas
« Reply #21 on: 17 March 2010, 00:31:26 »
dash would be nice....not much else though.
 ;D
    • E250 Est / Elroq
« Reply #22 on: 17 March 2010, 07:47:34 »
Out of interest, would the mod work on a prefacelift?
« Reply #23 on: 17 March 2010, 08:03:07 »
sadly not, its a very different setup.
« Reply #24 on: 17 March 2010, 08:25:31 »
It would on mine!  ::)  ::)  ::)  ::)  ;)
Welung666
« Reply #25 on: 17 March 2010, 11:43:51 »
It will on mine to... I have a facelift skuttle fitted :P
« Reply #26 on: 17 March 2010, 12:18:19 »
Becareful though. Apart from the obvious differences, a prefacelift bonnet is different above the passenger washer jet, there's less room. If you fit a facelift washer on the nearside, your prefacelift bonnet will push it back down as you close it. You might guess how I know!  ;D  ;D  ;D  ;D
« Reply #27 on: 17 March 2010, 12:56:50 »
Thats because you are trying to fit a superior facelift part, on the inferior pre-facelift  ::)  ;D
« Reply #28 on: 17 March 2010, 15:21:57 »
But why have an Omega if it looks like an Astra G?  ;)
« Reply #29 on: 17 March 2010, 23:09:02 »
Heres a pic
I've just noticed...
TB and Tunnie will be unhappy with you, not towing the party line.
 ;D
Pages: 1 [2] 3  All   Go Up
