Author Topic: Alloy wheel refurb  (Read 2961 times)
Kieran
  • Dorset
Alloy wheel refurb
« on: 20 March 2010, 19:38:26 »
I need to fix slight kerbing on one of my alloy wheels. Being a tight git i want to do this myself. Now after you have cleaned the area can you use good old P40 to repair any small indentations or does it have to be a filler specially made for Alloys. If so any idea what filler do i use.
Thanks for your help
Kieran
« Last Edit: 20 March 2010, 19:38:38 by kieran »
gstylebaby
  • stockport
Re: Alloy wheel refurb
« Reply #1 on: 20 March 2010, 23:27:04 »
Hi mate get on to detailing world i'm sure one of the guys over their will be able to help you out. :y
Kieran
  • Dorset
« Reply #2 on: 20 March 2010, 23:38:21 »
I have had a look on how to do wheel refurb and they seem to use a putty. I am not really sure if that is just an American way of saying body filler or is it a special filler that needs to be used.
Kieran
unlucky mark mv6
  • tipton,west mids
« Reply #4 on: 21 March 2010, 21:45:31 »
A good many people use normal filler mate,my mate for one who has his own bodyshop. :y
« Reply #5 on: 21 March 2010, 21:52:43 »
but how durable is normal car filler compared with proper epoxy-type fillers, it's got to be able to withstand a tyre fitter & a tyre machine  ;). I've used similar to the above wheel putty link & it sticks like the proverbial to a blanket & it pretty hard.
unlucky mark mv6
  • tipton,west mids
« Reply #6 on: 21 March 2010, 21:56:39 »
Thats a question that has been bugging me actually.Do the tyre machines actually touch the rim of the wheel,as i said the same thing to my mate,and he reckons they shouldent touch the rim. :-/
« Reply #7 on: 21 March 2010, 22:02:11 »
He's probably theoretically correct, they lever over a small bar to get the tyre started, but ........    ::)  ::)  ;)  ;D
unlucky mark mv6
  • tipton,west mids
« Reply #8 on: 21 March 2010, 22:08:11 »
And its a big but ::).I have actually seen that steel putty in the local bulldog spares.Can you actually sand this stuff down though. :-/
« Reply #9 on: 21 March 2010, 22:11:52 »
Yes! Sand it or file it.  :y
hotel21
  • The Kingdom of Fife
« Reply #10 on: 21 March 2010, 22:12:44 »
Used to use this stuff.....
http://www.itw-devcon.co.uk/index.php?/devcon_mro/epoxy_maintenance_repair_and_overhaul_systems/devcon_plastic_steel_putty_a/
.....when on board the boats many moons ago.  You used to get steel, brass, bronze etc.  Once set, it could be drilled, tapped, filed and generally machined however you want and lasted for months and months.  Great on bronze seawater pump casings that had been eroded, especially in the slip ring area.  Also got a release agent for it so that you could form it to a particular shape and NOT make it stick, so as to make a master from which 'castings' could be made.
Usefull stuff....   ;)
« Reply #11 on: 21 March 2010, 22:18:12 »
Grey Funnel Line often used a similar stuff - Belzona http://www.belzona.com/products.aspx That was over 20 yrs ago now, and I believe it was very expensive at the time.  ;)
