Pages: 1 2 [3]  All   Go Down
Author Topic: all set for LPG Day 1  (Read 5073 times)
Re: all set for LPG Day 1
« Reply #30 on: 24 March 2010, 22:20:30 »
Does look very interesting Tunnie, looks like you've got enough assorted parts to be building a second car  ;D
If you fancy a hand, i.e with the easy stuff liking making the tea I'm more than happy to pop over for a bit  :D
Not my place to say yes... But Tunnie assures me there's plenty of Bacon butties to be cooked ::) ::) ;D ;D
Be nice to meet you :y
Your very welcome Josh, need someone to load the BBQ with bacon  ;D
Seriously though your welcome to pop down if your not doing anything  :y
Mmmm bacon  :D
That sounds about the right skill level for me.
If you don't mind, I'll pop down if I've got some free time...what sort of time?
All day... I should be there by 9 at the latest, traffic permitting
« Reply #31 on: 24 March 2010, 22:21:41 »
Josh - Any time mate, in fact anytime over next 3 days  :y
LD - Err i am not the strongest chap in the world as many who have met me will comment  ::) - Back the car in and we can use the boot as the tool box  ;D
Albs - Course you can, Senator wiring job did not look great, but it worked  ::)
« Reply #32 on: 24 March 2010, 22:27:43 »
I managed to lift it in on my own, so you'll be fine... 4 wheetabix for brekkie young man ;D :y
« Reply #33 on: 24 March 2010, 22:52:20 »
Just a quick one. Might well be a stupid question:
I assume it's a Z22XE with Simtec management?
TIS seems to show a Motronic diagram too. :-/
« Reply #34 on: 24 March 2010, 22:59:32 »
think all 2.2 petrol in Omega are Z22XE?
« Reply #35 on: 24 March 2010, 23:19:40 »
OK. Pinouts for SIMTEC:
+12v ignition switched feed   Black X84 Pin 64
Tachometer                          Green X84 Pin 62
Mixture control Lambda         X83 Black Pin 57 signal pin
                                            X83 Grey  Pin 8 ground pin
If you look at the routing of the looms from the ECU X83 is the connector where the loom heads round the engine itself. X84's loom heads through the bulkhead into the car.
I think the Lambda sensor pin you want is pin 57 but I've included pin 8 in case I've got them the wrong way round.
The ECU connectors are a bit dense so I find the best way is to find the pin on the connector, trace the correct coloured wire from that pin up the loom a little and scrape the insulation and solder there then insulate.
You might need to solder in connections to the petrol injectors as the connectors are part of the cable tray that sits over the injectors.
« Reply #36 on: 24 March 2010, 23:20:44 »
Yep. Just saw some references in TIS to Y22XE and a motronic ECU.
david_omega
« Reply #37 on: 24 March 2010, 23:27:48 »
All that stuff to gas a car.
Good Luck to you friend.
When you have finished yours' you are more than welcome to play with mine, I think I could have phrased that better. ;D ;D ;D ;D ;D
gross
« Reply #38 on: 24 March 2010, 23:29:33 »
Thanks Kevin :y :y
Looking forward to that now ::) ::)
Pages: 1 2 [3]  All   Go Up
