Author Topic: LPG Guides  (Read 3257 times)
    • E250 Est / Elroq
LPG Guides
« on: 05 April 2010, 08:39:20 »
We are in the process of adding a new index section to the maintenance guides dedicated to LPG Fitting & problems.
Huge thanks to all involved in the creation of the guides, some real team work going on  :y
fair few to add, so they will move from test to the guide section in dribs and drabs  :y
« Last Edit: 05 April 2010, 08:40:08 by jimbob »
    • E250 Est / Elroq
Re: LPG Guides
« Reply #1 on: 05 April 2010, 09:20:36 »
Thats 4 guides in with more to come.
Huge thanks to the 'LPG crew'
Cheers Lazydocker, Tunnie, Kevin et al.
« Last Edit: 05 April 2010, 09:20:43 by jimbob »
Re: LPG Guides
« Reply #2 on: 05 April 2010, 09:26:15 »
guides are looking good  :y
Re: LPG Guides
« Reply #3 on: 05 April 2010, 11:56:14 »
LD has asked if i could rustle something up re fitting a donut tank, should be able to sort something in the next couple of weeks if/when it ties up with an insurance issue on the rear bumper.
Re: LPG Guides
« Reply #4 on: 05 April 2010, 17:03:46 »
Keep up the good work fellas!, don't forget, this numpty, is going to need all the help I can get when the time comes, especially with the electrical/electronic connections! ;D ;D ;D ;D ;)
Re: LPG Guides
« Reply #5 on: 05 April 2010, 17:12:51 »
All looks good ..  :y :y :y :y
Lots of hard work, both on the actual work and the guide ... well done mate  :y :y :y
Re: LPG Guides
« Reply #6 on: 05 April 2010, 17:15:38 »
I am working on a section covering the electricals. :y
Re: LPG Guides
« Reply #7 on: 05 April 2010, 18:24:47 »
is now a.good time to ask about the tow bar electrics guide as well ?  :-X
Re: LPG Guides
« Reply #8 on: 05 April 2010, 19:13:29 »
Right, so KW is doing the electrics (I assume connections only?) and I'll cover cable runs when I do the front end sections.
Chris is doing a Vertical Toroidal tank section.
Anything else anyone can think of?
Kevin, do you want to do a section on the software, ECU upgrade and calibration/mapping too or do you want me/Chris to do it so you've got more time for other things?
Re: LPG Guides
« Reply #9 on: 05 April 2010, 19:13:33 »
Pikey!
Re: LPG Guides
« Reply #10 on: 05 April 2010, 19:15:05 »
Pikey!
Your point being? Bearing in mind you want at least one of the 3 members who have/will have tow bars to help re-fit/finish the LPG on silver bullet :-X ::) :-?
Re: LPG Guides
« Reply #11 on: 05 April 2010, 19:18:28 »
No Problem. Leave it to me. :y
Re: LPG Guides
« Reply #12 on: 05 April 2010, 19:20:25 »
PMSL. Last time I saw the silver bullet it was relying on a pikey bar as its' sole method of propulsion.  :D
Re: LPG Guides
« Reply #13 on: 05 April 2010, 19:22:57 »
 ;D ;D ;D ;D ;D ;D ;D
So will the Golden Nugget now :-X :-X :-X
Re: LPG Guides
« Reply #14 on: 05 April 2010, 20:45:52 »
I was thinking of filling exhaust with petrol, and lighting.....
