my vectra diesel has died need ideas
Started by peter19730, 10 April 2010, 11:57:28
peter19730
can anyone help my veccy has just cut out whilst driving along and wont start, ive got fuel comin up to the injectors as i have cracked 1 open but it just will not fire up
Welung666
Have you tried reading the codes? Follow the link in my signature (below) and see if you can read them.
peter19730
aa chap tried but said the my vectra was missing pin 6 and he couldnt get anything from his gizmo as my car is pre 2001
Welung666
Shame your such a distance away or I'd have put my "My Naff Code Reader" on it. Is the EML on? Is it flashing while cranking?
peter19730
hooked it up to my miggy friday as battery went flat trying to start it and turned ignition on eml came on and went off straight away and i didnt notice anything flashing whilst cranking it over but other than that i cant say i noticed it when it broke down
peter19730
have had it running by spraying easy start up the air intake but other than that im stumped
hoofing it
Fuel pump failed if your getting fuel to the injectors and its not starting the pump might not be delivering the correct preasure to crack the injectors.
Have you checked the timing chain.
set the timing marks up and take off number 1 injector feed at pump put a small piece of wire in the hole then by hand turn crank slowly if the wire moves the timings out.
only move the crank about 10 degrees either way.
UrbanFox
is it a 2.0 Veccy diesel?  These are known for problematic diesel pump failures, often being the electrics that have failed.
HNO3GOH
Fuel pump :( get the last 3 numbers off the pump (eg 003 or 017 etc) and then get your self on ebay as you can pick them up for about £15 but just make sure that the last 3 numbers match:y
Couldn't this be a fuel pump ECU issue, or is it only the 1.7 diesels that suffer this.
Ian_D
Hmm, not sure if I trust ebay...
I've got a pump sat in the garage that was sold to me as a 'runner'.
I fitted it to a Vectra I had, and never got it running. Bought another pump from ebay, and exactly the same again.
Cut my losses in the end and sold it as a non-runner.
So who knows, pump I've got could be fine? ::)
[move][size=12]
[color=#ff0000] LMF are utter rubbish - dont buy steering idlers from them! You've been warned![/color][/size]
[/move]
Ian_D
QuoteCouldn't this be a fuel pump ECU issue, or is it only the 1.7 diesels that suffer this.
If I remember correctly, yes that was the 1.7's - they have a removable ecu.
However, the electrics often fail in the 2.0td's, but they are sealed and part of the pump itself so can't really be replaced.
[move][size=12]
[/move]
UrbanFox
Apparently there is someone on vvoc who can repair the electrics..
peter19730
tried again to no avail to find a way of reading the fault codes but have had to give up as nothing seems to be working, time to sell up me thinks
