Author Topic: Common Omega Parts List  (Read 6306 times)
Re: Common Omega Parts List
« Reply #15 on: 28 April 2010, 22:04:33 »
Has no one else got, or want to make a contribution to this list?? :o :o :o :o
There must be far more "common servicing parts" than the list shows currently?? :-/ :-/ :-/ :-/ :-/
Lizzie, here is a copy of the parts list I have gathered for my 2.2, apologies if any are duplicated with what you have already  :y
Car Mats............................: Part No. 91132419
Paint Code.........................: Z2AU 157  (Star Silver3)
Touch Up paint...................:   "   "  91158299 (ditto)
Aerosol Spray Can..............:  "   "  91158298 (ditto)
Throttle Body Gasket..........:  "   "  90543950
Breather Sump Gasket.......:  "    "  90500571
Check Strap Bushes...........:  "    "  90462823
Cam Cover Black sealant....:  "    "  90485251
Cam Cover Gasket.............:  "    "  55558349 x1
O-Ring Gaskets..................:  "    "  90528438 x10
Anti Freeze Coolant (Red)..:  "    "  1940650/09914431 ( Approx. 6.5 Litres )
Engine Oil, 10w 40.........: Approx. 5.0 Litres
Front Brakes...............: Vented Discs (296 mm)
Rear Brakes................: Disks (286 mm)
Front Tyres................: 235/45 R17
Rear Tyres.................: 235/45 R17
Spark Plugs................: Part No. 9195109 Bosch FLR8LDCU or equiv.
Gap = 1mm, Tighten to : 25Nm (18.43ft/lbs) (216.28in/lbs
Cam Sensor.........................:   "   "  90520850
Crank Sensor.......................:   "   "  9148306
Radiator..............................:    "   "  52485464
Battery Orig. Equip..............:   "   "  19003129  (55amp/Hour)
Ignition Coil Pack.................:   "   "   9195819
Air Filter................................:   "   "  91149684
Cam Belt Kit..........................:   "   "  93174267
Cam Sprocket Locking Tool...:   "   "  KM-853 (Draper?)
Cam Belt...............................:   "   "  9128722
Fan Belt (air/con)..................:   "   "  93181718
Fuel Filter..............................:   "   "  25313359
Fuel Pump.............................:   "   "  9196213
Pollen Filter...........................:   "   "  93165208
Wiper Blade (Driver)..............:   "   "  93177183
  "     "       (Passenger.)........:   "   "  93177182
Shock Absorber(Front)..........:   "   "  72119076 (Left Hand)
  "      "       "   .......................:   "   "  72119077 (Right Hand)
Shock Absorber(Rear) ..........:   "   "  90542942
Thermostat Assembly............:   "   "  90501081
Heater Byepass Valve (HBV).:   "   "  90566947
Water Pump..........................:   "   "  24409355 (R1160032)
Exhaust Manifold...................:   "   "  24420438
EM to Head Gasket................:   "   "  24443291
EM to Downpipe Gasket........:   "   "  9157096
Ex. Manifold to Head Studs...:   "   "  24578147
  "      "    "   "  Nuts...............:   "   "  11082413
EM to Downpipe Nuts............:   "   "  9157116
EM to   "      Studs...............:   "   "  11098631
EM to   "      Gasket.............:   "   "  9157096
Thanks Phil for that! :y
I will incorporate your list into the master 8-) 8-)
« Reply #16 on: 29 April 2010, 19:02:23 »
At long last Part Nº for Oil Filter (Screw on) is 93156954  :y
Also Sump plug (Torx) 96023264
Breather bridge to plenum seal 90467543
Breather bridge to throttle o-rings 90500983
HTH
« Reply #17 on: 29 April 2010, 19:51:29 »
Following my thread on creating a list of Omega simple Vx servicing part numbers, common across the Omega range, I now present the list covering those that I know.  Can those with the knowledge please enter others (?)
Description                                             Vx Part No.
Spark Plugs                                            009195109
Cam Cover Gasket (x2 sets V6 only)     090511451
'O' Ring (cover bolt holes x 16 V6 only)  090411826
Cam Cover Gasket (x1 set 2.0/2.2 only)  55558349
O-Ring Gaskets (x10 2.0/2.2 only)         090528438
Sealant (Black for Cam Cover Gaskets)   090485251
Air Filter                                                  091149684
Pollen Filter                                              093182438
Oil Filter (Canister paper type)                  009192426
Oil Filter (Screw on)                                  093156954
Petrol Filter                                              025313359
Petrol Filter Clips                                      090542453
Fuel Pump                                                  09196213
Engine Oil 10/40 Semi Synthetic                093165216
Also Sump plug (Torx)                              096023264
Breather bridge to plenum seal                  090467543
Breather bridge to throttle o-rings             090500983
Anti-Freeze                                              093170402
Brake Fluid                                               093165410
Brake Sensor                                           090495144
HBV  (Heater Bypass Valve)                      090566947
Throttle Body Gasket                                090543950
Cam Belt Kit                                             093174267
Cam Belt                                                    09128722
Fan Belt (air/con)                                        93181718
Cam Sensor                                               90520850
Crank Sensor                                             09148306
Breather Sump Gasket                              090500571
Thermostat Assembly                               090501081
Water Pump                                             024409355
Radiator                                                      52485464
Battery Orig. Equip (55amp/Hour)              019003129
Wiper Blade  (RHD Driver Side)                   093177183
Wiper Blade  (RHD Passenger)                    093177182
Lock Solenoid                                           090493702
Headlight Level Sensor                              093197245
Door Check Strap Bushes                           90462823
Car Mats                                                  091132419
Updated 29/04/10
« Last Edit: 29 April 2010, 20:16:30 by Lizzie_Zoom »
« Reply #18 on: 29 April 2010, 19:54:39 »
I have now added most of the parts listed, but have not added those that I think are not universal across the range, but (maybe) just for your 2.2.  EDITI have highlighted these; can you confirm universal status please? ;)
I have added the cam belt kit, but is this the  same across the range? :-/ :-/
Thanks again ;) ;)
« Last Edit: 29 April 2010, 20:11:39 by Lizzie_Zoom »
« Reply #19 on: 29 April 2010, 19:55:16 »
HTH
Thanks dbug; now added ;) ;)
    • E250 Est / Elroq
« Reply #20 on: 29 April 2010, 20:08:08 »
was leaving this to see where its going....
IMHO...
A good idea in principal....
A few thoughts.....
The list is getting a bit big an unmanageable, maybe split into Headings like common service parts, Cam cover gasket parts etc.
Also the accuracy worries me, consider saying what engine the parts are for, as for example there are :
7 types of cambelt kit
2 types of pollen filter
5 types of oil filter
3 types of sparkplug
5 types of battery
etc etc etc, the list goes on.
Not trying to dampen what you are trying to do, but fear it could be a bit of a white elephant...
If the information is not complete, then people may well end up incorrectly ordering the wrong parts, which can be an expensive mistake on special order bits.
A lot of people on here have access to the proper Vauxhall documentation in the form of the trade club site, or epc itself, maybe best left to requests and answers  :-/
That said, if you pm me your email, I can send you something which may help.
We did at one point have a full tradeclub list of parts / prices but it was not easy to maintain accuracy so it was removed.
andyc
  • Norfolk
« Reply #21 on: 29 April 2010, 20:23:13 »
This could turn into a labour of love for someone. Agree with Jimbob, nice idea but the way GM change part numbers is a nightmare.
Even looking at some of the numbers already on the list i can tell you some are superseeded.
You then have all the engine number chages, chassis number changes, no break point changes (GM don't know when they changed a part).
All i'll say is a great idea but anyone using the list double check the numbers are correct for your car, If your local is having a problem PM your vehicle details and i'll do my best to help out.
Once again great job and please don't think i'm stepping on anyones toes 'cause i'm not.
Thinking about it it might be a better idea to lay it out on spread sheets for each section of the car like EPC does. Eg
Bodywork Exterior
Bodywork Interior
Front Axel & Suspension
Rear Axel & Suspension
Engine
Trans
etc etc
Just an idea
Cheers
Andy
Thetford. Norfolk
« Reply #22 on: 29 April 2010, 20:24:27 »
IMHO...
A few thoughts.....
5 types of battery
Thanks JB :y :y
I was awaiting this type of input, as I myself is becomming rather concerned about the complexity of the different parts for different models i.e. on the cam cover gaskets, and cam belt kit front just for starters, so I hear loud and clear what you are saying!!
Thinking further on what you have said, and what you say has been tried before, I think it best that we terminate this exercise now before someone does get totally confused and order the wrong parts!! :'( :'(
Thanks for all that tried to contribute to the list, but it just shows how something that seems so simple to undertake becomes a monster once being started!! ::) ::) :D :D :D ;)
« Reply #23 on: 29 April 2010, 20:25:50 »
Bodywork Exterior
Bodywork Interior
Engine
Trans
etc etc
Just an idea
Cheers
Andy
Thanks Andy!  You are right, and please see my reply tyo Jimbob 8-) 8-) ;)
andyc
  • Norfolk
« Reply #24 on: 29 April 2010, 20:37:44 »
Hi Liz
It was worth a try and like you said something that seems so simple can turn into a monster just like that.
I've the same problem in my own workshop. I 've been logging all the new and used parts that not just for my self but other friend have stored, we have a bit of a group buying thing going on.
I have to list parts for B series Manta's, A  Series Senators, Monza's, Opel GT's, Cavaliers, Mk2 & 3, Nova's and of course Omega's
I'm two years in and still haven't scratched the surface
Christ i do this for a living and a hobby...........i need to get a life ::) :y
Cheers
Andy
Thetford. Norfolk
« Reply #25 on: 29 April 2010, 20:46:23 »
Hi Liz
Cheers
Andy
 :D :D :y
« Reply #26 on: 29 April 2010, 20:57:48 »
Thanks again ;) ;)
Hi Lizzie, I really cannot say whether those items fit omegas other than the 2.2 petrol? :-/  Sorry  :-[
