Project Estate - Progress
Started by JamesV6CDX, 28 June 2007, 07:44:49
Progress on the project Estate is as follows:
1) Replace leaking sump plug and oil filter. Has much reduced (but not cured) the oil loss.
2) Replace oil pressure switch (this has helped)
3) Remove plenum and inlet - check valley. No leaks. Check Oil cooler to block unions - no leaks.
4) Check cam-covers - no leaks.
5) Strip down, remove cambelt, remove toothed crank sprocket (breaking it in the process), and remove crankshaft oil seal. Looks like there's been a leak in this area.
Next job is to install the new seal, and put it all back together.
Only other job on top of that, is a new door, and it'll be singing and dancing.
Then I need to find the V5 for my Elite and sell it.... and get my old CDX taken to the scrappy... hopefully to make room for TD's 51 plate Veccy, that we may have struck a deal with...
Oh, and now it's running on Vx 10w/40, instead of used 20w/50 - the lifters have stopped making a noise ;D  ::)
I must add... I have put 3 OOF stickers on here - one in the back window, and one on each of the rear side windows. Looks really smart, not in your face, but tasteful.
Bo Bo
QuoteI must add... I have put 3 OOF stickers on here - one in the back window, and one on each of the rear side windows. Looks really smart, not in your face, but tasteful.
Guess that would work in an estate.....
Craig_R
Did You talk about the Black Stuff   :-X brave man  ;D
Your Putting alot in to this one james I guess its Love eh.
An estate will be better for you mobile mechanic work also. Ever Thought Of getting it to run on Gas
Craig
Mod's
[To be Fitted]Reverse Sensors
Good point Craig, you can fit a lot of tools in an Estate James!
Craig_R
He also Needs some more Stickers for the side and back saying 'Omega Owners Mobile Mechanic' and an Orange light for the top  :)
Mod's
Markie
QuoteGood point Craig, you can fit a lot of tools in an Estate James!
ive got a tumble drier ( going to tip) a tow bar and two sets of golf clubs in mine currently  :y
