Confirmation needed on plenums
Started by megaomega123, 23 June 2007, 22:08:29
megaomega123
Am I right in thinking that a 3.0 has the extended plenum. Below are 2 pics one is 2.5 the other a 3.0. Can anybody confirm the extended plenum or if I have misunderstood something?
Darth Loo-knee
The earlier 3.0 model had the short Plenum too :y
megaomega123
Great thanks. It did have a sticker with x30xe
Extended plenum on mini facelift 3.0l (mid 97 on), not on 2.5 as 2.5 is better with smaller one.  2.6/3.2 have extended plenums, although the 2.6 would be better off with shorter one but no room for throttle servos on shorter one.
ians
Those are both the same (short/original version) (I think..?)  The extended plenum is significantly different and I think the black plastic bit comes in separate sections.  I'm sure someone can post a pic.
CaptainZok
QuoteThose are both the same (short/original version) (I think..?)  The extended plenum is significantly different and I think the black plastic bit comes in separate sections.  I'm sure someone can post a pic.
Looks like a job for Markjay then.
TuBy's new whipping boy.
familyman
Looking at those pics has reminded me does anyone know the part no. for the gasket for the egr onto the side of the plenum chamber on an early x25xe as VX keep sending a totally different one insisting their right and i'm wrong even though i've got the car in front of me.
It's a bit difficult on time to go to a dealer but at this rate i'm going to have to take an extended lunch break plus petrol just to sort a £2-£3 gasket
Sorry for the change of thread guys
You came in that, your braver than i thought
raximax
thank god you had me going there lol :y
mmeeggaa
megaomega123
Quotethank god you had me going there lol :y
Is that why you were down on power on the way home  ;D Thought you only had 2.5 under there.
MikeDundee
QuoteExtended plenum on mini facelift 3.0l (mid 97 on), not on 2.5 as 2.5 is better with smaller one.  2.6/3.2 have extended plenums, although the 2.6 would be better off with shorter one but no room for throttle servos on shorter one.
Is that cos it makes it easier to change the cambelts ::)
hotel21
Heres a pic of an engine with an elongated plenum.
Markjay
#11
I was beaten to it by our friendly Scotsman  ;), but here's one anyway (this is from the Maintenance Guides section):
Alas, no more Omegas....
