Pages: 1 [2] 3  All   Go Down
Author Topic: All up in flames  (Read 7741 times)
Re: All up in flames
« Reply #15 on: 28 May 2010, 21:07:59 »
Gutting to see that, dude - hope you can sort it somehow!
Maybe a silly question, but what is a power sounder?
Alarm related?
How does one disconnect it to avoid the misery of a fire?
It is a siren, but a siren with a difference, it has built in rechargeable batteries, and is hidden from the outside world.
Theory being, you can cut the horn wiring, disconnect power etc, but on detection of an alarm condition, or power loss, then this will sound on its own.
Great in theory....till it breaks down and causes a mess like above.
Its these that the warning under the bonnet about disconnecting the battery within 15 seconds of turning off the ignition is about, thats the 'command' not to go off.
« Reply #16 on: 28 May 2010, 21:29:26 »
release torx bolt on drivers side scuttle, reach in and plug the pesky git  :y
« Last Edit: 28 May 2010, 21:29:41 by tunnie »
pedroMV6
  • York
  • Der Metzgermeister
« Reply #17 on: 28 May 2010, 21:38:45 »
2 jobs for tomorrow then - cheers guys!!!
I tried to disconnect the battery on the Elite once, and an alarm went off.
Put key in ignition and switched to 1 and then tried again, all well. (Trick remembered from my sad, V*ctra B days)
That the power sounder?
« Reply #18 on: 28 May 2010, 21:40:46 »
Yup, once disconnect you can change a battery in peace!
gstylebaby
  • stockport
« Reply #19 on: 28 May 2010, 21:42:12 »
Sorry to see this mate.  :'( :'( :'(
Not sure i have a power sounder on mine as its an early one will have to check. :-/ :-/ :-/
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #20 on: 28 May 2010, 23:26:21 »
Is there not a possibility for an insurance claim?
Olympia5776
  • Ireland
« Reply #21 on: 28 May 2010, 23:41:50 »
That's horrific ................ :o
So horrific it made me get up and go out to the garage / workshop and disconnect mine just now . It's sitting next to my Manta and all my tools and equipment for our Property Maintenance and Renovation business .
Doesn't bear thinking about....... :'(
I hope you get a satisfactory settlement for the car , good luck. :y
coastie123
  • sidmouth, devon
« Reply #22 on: 29 May 2010, 00:01:35 »
sorry for your loss...
im going to disconnect mine in the morning (if i can find it)..
as olympia says "hope you get a satisfactory settlement for the car"
regards
shaun
« Reply #23 on: 29 May 2010, 08:07:07 »
first thought, power sounder. But the damage inside the car does looks worse than that in the bonett/bulkhead area.
..... soldered new batteries into mine, hopefully they'll last another 7 years.
Very sorry to see this Nially, very best of luck with the insurance.
doog
  • Alloa Central Scotland
« Reply #24 on: 30 May 2010, 13:14:07 »
It happened to me too
 now i disconnect the power sounder the first day i buy an omega
Doug
« Last Edit: 30 May 2010, 13:14:24 by doog »
me at kick boxing
NiallyV6CDX
  • County Down
« Reply #25 on: 30 May 2010, 21:45:22 »
Well thanks for all the condolences. :-/ :) I told the insurance what happened and they said I would lose 2 of my 5 years no claims if I claim for it. that would bump my premium up to over £3000 living here. For a payout of £300 if I'm lucky, I'm better off not claiming salvaging what parts I can from it otherwise I will not be able to afford to get another car with premiums like that. Most of the engine and exterior are still good as are the wheels and exhaust. So Im hoping I could get a couple of hundred for those.
Just out of interest, is this power sounder problem shared with other vauxhalls or just the omega?
Welung666
« Reply #26 on: 30 May 2010, 22:41:52 »
Common across most of the Vx range.
« Reply #27 on: 31 May 2010, 00:54:06 »
I have seen 3 different types used on Omegas. Not sure spontaneous combustion is a speciality of any particular model though.
The problem as I see it, is that the supply wiring to the power sounder is not adequately protected against a fault. The wires to the power sounder are tiny (no problem there. It takes about a quarter of an amp, and the wires are probably safe up to a few amps).
The problem is, this puny wiring is protected only by an 80 amp fusible link in the positive distribution box, and nothing on earlier cars without the box.
I suspect this is why the dash tends to go up too. Wiring is damaged through the loom until it reaches an adequately rated feed, probably by the fuse box.
Why, oh why didn't GM follow the fundamental rule of electrical safety and fuse the wire appropriately at the point where it is fed?
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #28 on: 31 May 2010, 15:56:13 »
Another one toasted, sad to see.
Can we not have a warning sticky on this for Newbs? makes sense to me.
I_want_an_Omega
« Reply #29 on: 31 May 2010, 16:03:46 »
There 2 "devices" in that area, both are unplugged on mine - one is defo a horn type device - but whats the other one for?
Would an insurance co get upset if you disconnected it?
Pages: 1 [2] 3  All   Go Up
