Drilled the Manifold for LPG nozzles
Started by JamesV6CDX, 03 June 2010, 21:22:03
Well after removing the fuel / electronics, I have drilled the fanimold on the V6 tonight for the LPG nozzles.....
I was really nervous about this job, but actually. it's not too bad, if you take your time and have a steady hand. I have managed to get my nozzles really close up against the petrol injectors, as per Kev's install, so am pleased :y
My only queestion are - I have a bit of a mixed bag of nozzles
I have 4 of the "usual" ones, with an 8mm hex fitting and I think a 4mm pipe connection, and 2 different (alan key fitting) ones.
Now, the internal diameters are the same on both - so flow shouldn't be an issue - but, would it affect it if I use 4mm pipe on the 4, and 5/6mm pipe on the other two? Would this affect flow?  :-/
That reminds me - I have 3 manifolds here to get to Mr Nozzle Driller, aka Mr Wood....
QuoteThat reminds me - I have 3 manifolds here to get to Mr Nozzle Driller, aka Mr Wood....
Have a go Jaime - is a peice of cake if you take your time :y
I've Kevin already done mine, been on LPG for a few weeks.  These are spares that Kevin was going to get predrilled for other members considering LPG...
If it's not particularly urgent, I could collect them and do them when I come and badger you for ECU updates  :D :y
I've already got a couple of spares from you. Are there more? :o
3 on my garage floor.  I think 2 x 2.5 and 1 x 3.0....
And I have a spare one to swap for a drilled one from Mr Wood at The Lakes.  :y
QuoteAnd I have a spare one to swap for a drilled one from Mr Wood at The Lakes.  :y
Glad you reminded me. :-[  ::)
I think all the ones I currently have are 3.0 so the 2.5s would certainly be worth hanging on to.
The spare one I have is a 3.0 one which I presume is the same as a 3.2 one?
Yes, I think so.
whats the differance? thought the inlet was the same tbh? :-/
Quotewhats the differance? thought the inlet was the same tbh? :-/
There's a mark in the casting indicating which is which. Either "25" or "30". I assume the ports are slightly narrower on the 2.5 but don't have a pair to compare.
Any of you chaps have any thoughts re my nozzle/pipe query?  (first post) :)
