Author Topic: are there any members...  (Read 3600 times)
stuthespread
  • stevenage,herts
  • no spring chicken
« on: 02 July 2010, 19:18:15 »
on this forum that have destroyed engines due to cambelt failure.I only ask because it seems to be an absolute must change at 40k or 4 years?
Re: are there any members...
« Reply #1 on: 02 July 2010, 19:29:32 »
Yes, at the latest or you will lose an engine ;) ;)
    • E250 Est / Elroq
« Reply #2 on: 02 July 2010, 19:32:27 »
been several, I was a (very) unlucky one...
Kit was faulty and managed about 5 miles!
Heads off, new valves etc, all thanks to Mark DTM
We had just swapped the heads on mine, new cambelt kit, on the test drive a new tensioner let go....clatter clatter clatter  :'(
stuthespread
  • stevenage,herts
  • no spring chicken
« Reply #3 on: 02 July 2010, 19:44:41 »
any come backs on that kit?
    • E250 Est / Elroq
« Reply #4 on: 02 July 2010, 20:27:47 »
Never tried, Mark rebuilt my engine using the parts we had previously removed, and fixed the kit.
Too much hassle being stranded 100 miles from home etc, priority was to get mobile again, the money cost was luckily small, but the man hours high.
stuthespread
  • stevenage,herts
  • no spring chicken
« Reply #5 on: 02 July 2010, 20:35:26 »
anyone with a 4 pot had this problem?
    • E250 Est / Elroq
« Reply #6 on: 02 July 2010, 20:39:37 »
« Reply #7 on: 02 July 2010, 20:42:42 »
4 pots more prone to it because waterpump is cambelt driven, i've seen number of posts on 4 pot cambelt failures due to water pump
« Reply #8 on: 02 July 2010, 20:54:50 »
Would you really want to tempt fate Stu?
pedroMV6
  • York
  • Der Metzgermeister
« Reply #9 on: 02 July 2010, 20:59:09 »
Why risk it?
Cost a damn sight more if it did let go through being on there too long.
stuthespread
  • stevenage,herts
  • no spring chicken
« Reply #10 on: 02 July 2010, 20:59:11 »
is it because these engines are 16valve because i've had 5 cav 8 valve cars and i've had cambelts go on at least 3 of them with no damage to the valves etc whatsoever?
pedroMV6
  • York
« Reply #11 on: 02 July 2010, 21:01:35 »
8 valvers are a different kettle o'fish!
Guess you mean this car :
"Drives: 1999 2.5 gls with black leather"
Which means you got 24 valves and four camshafts to worry about.
« Last Edit: 02 July 2010, 21:05:31 by PedroMV6 »
« Reply #12 on: 02 July 2010, 22:12:57 »
All Vauxhall 8 valve engines are normally "Safe" (no matter what the book says) and is worth chucking a new belt on.
All Vauxhall Multi-valve engines are "interference" and will bend valves at a minimum.
