ATF change ....YUK!
Started by omegod, 11 July 2010, 17:31:34
omegod
Having spent the weekend elbow deep in ATF I now declare it the worst job on a motor I have ever tackled..................SHOULD HAVE FITTED A B*STARD SUMP PLUG you bunch of GM arses! >:( >:( >:( >:(
Sorry for the rant!
Quote...................SHOULD HAVE FITTED A B*STARD SUMP PLUG you bunch of GM  .....
and a dip stick  ;) :y
QuoteHaving spent the weekend elbow deep in ATF I now declare it the worst job on a motor I have ever tackled..................SHOULD HAVE FITTED A B*STARD SUMP PLUG you bunch of GM arses! >:( >:( >:( >:(
Sorry for the rant!
Their excuse is, it was designed to be 'sealed for life' ;D ::)
Darth Loo-knee
Sorry I had to smirk reading this thread.... You do get a little covered in the smelly oil don't ya lmao
omegod
Not arf Daz!! But seeing the crap that had been in there for 144,000 miles it's worth the hassle.
Seems to change a lot smoother now.
CaptainZok
QuoteSorry I had to smirk reading this thread.... You do get a little covered in the smelly oil don't ya lmao
Same as changing gearboxes eh Daz? ;D ;D
TuBy's new whipping boy.
Shrek
#6
How easy would it be to put a sump plug or similar in there .... surely cant be that difficult to weld or put some kind of plug in there ??
I quite fancy changing my atf but this is whats putting me off  :-/
"My Naff Code Reader" and OBD2 readers available .
mrjimbo
I feel your pain  ;D  I did mine on Friday and the drive still looks like a disaster zone, nothing seems to want to shift it   >:(
Darth Loo-knee
QuoteHow easy would it be to put a sump plug or similar in there .... surely cant be that difficult to weld or put some kind of plug in there ??
If you leave a couple of bolts in at the end of the sump then gently loosen them the oil will come out more controlled... he says ;D what Zok is refering too is I was changing his gearbox with his son Tony, oikl was pouring out when I asked my Nephew to pass me a screwdriver or spanner, so he passes it to me so I have to lean forward to get it........ yes oil all over my bloody head ;D ;D ;D you can imagine what those three were doing can't ya ;D ;D ;D ;D
As Daz says, did snigger a little.
Thing with the sump is you still have to remove it to clean the magnet, filter and gunk out the bottom of the sump including checking for bits of thrust washer ideally.
But yes it is a pita.  ;D
Not really, as you still need to remove both sumps - front to check state of thrust washer, and rear to clean/replace filter and magnet
Shrek
Im just thinking about the number of times i have read that this is a crappy job .... cant be that difficult surely to make some kind of pug or hole etc ??
Shrek
I just mean to get the oil out more easier without getting covered in it then removing the sumps once its drained  :y :y
CaptainZok
You do it on purpose to keep us amused, go on admit it.
Darth Loo-knee
Maybe so.. but not on that occassion ;D
