irmscher/prodrive spoiler
Started by OMEEEGAH, 10 July 2010, 20:01:23
OMEEEGAH
are they stuck on or bolted through ???  :D
Where i'm from its Omeeegah
Brikhead
Boot lid spoiler? Vauxhall usually use bolts and adhesive on 'em... On the Vectra you can see the bolts on the underside of the boot lid, along the edges. It's usually not worth trying to remove them, just swap the whole boot.
OMEEEGAH
#2
yep i have mucked about with many vectra irmscher spoilers and they bolt through on the b's  :D
never done a omeegah though,so they can be double sided taped on and not drilled  :-?,i have a thing about the drill slipping or causing the boot to rust  :P
unlucky mark mv6
Quoteare they stuck on or bolted through ???  :D
I beleive they are bonded on with shit loads of adhesive.Good luck if your removing it. :D
The Mini facelift Irmscher one is bonded with a screw either end but the Prodrive facelift one is just bonded ;)
