calipers
Started by The Red Baron, 12 July 2010, 16:51:57
The Red Baron
silly question maybe, rear callipers from a 2.5 gls estate as against rears from a 2.0l saloon. difference?.
As longs as both pre 2001, I believe they are the same.
i know early 2.0's had smaller front brakes, not sure about rears.  :-/
The Red Baron
QuoteAs longs as both pre 2001, I believe they are the same.
mini facelift, thanks j. :y
TC book lists 3 types :o
Up to some point in 1998 (including early minifacelifts)
Some point in 1998 to when they went vented
Vented
The breakpoint in 1998 is W1069516
The Red Baron
thanks, more usefull info there. :y
3.0V6
I have two 99 T 3.0 mininfacelifts, both running solid rear discs???
QuoteI have two 99 T 3.0 mininfacelifts, both running solid rear discs???
Jamie must've been on something. ;) The vented disc cut off is something like 2001. Your car has the correct solid discs .... like mine  :y
Jamie must've been on something. ;) The vented disc cut off is something like 2001. Your car has the correct solid discs .... like mineĀ  :y
nah .. what he says makes total sense ...
QuoteTC book lists 3 types :o
Vented
so -> 98  - small
98 - > ?  (2001 ?)  - large
? - end  - vented
makes sense to me .. :)
Sixstring
Umm.......were estates different???
Mine has vented discs on it, and mine's a 99 MFL........
QuoteUmm.......were estates different???
It would apear someone before you has been playing. Your brakes are now modified ..... not neccessarily for the best as the front - rear bias has changed. 2woody will explain .... that's his forte  :y  :y
Quote....
I suppose it does if you I read it properly in the first place  ::)  ::)  ::)   ;)
Sixstring
Andy......have original solid discs too, (loads of spare things when I bought car) should I change them back??
QuoteAndy......have original solid discs too, (loads of spare things when I bought car) should I change them back??
Stu/2woody did explain the difference in braking due to the difference in piston sizes between the two. I can't remember which way it was now ie whether you now have more or less braking at the back than it was originally. I suppose it's your call whether you put back to original. There have been various references to vented disc 'upgrade' at the back end, I suspect that it's just to say that you now have vented discs front & back.  ;)
Sixstring
TBH, didn't know they were changed at some point, assumed that they were original. My last saloon had solids on the back, thought...Estate-heavier-needs vented. When the P.O gave me loads of bits with car, just assumed they were saloon ones he didn't want.
I think I'm going to change them back...........(the other discs are pretty much brand-new, and so are the calipers)
