corsa lights
Started by sport, 13 July 2010, 23:34:50
sport
Hi my corsa head lights look like thay are crazed on the top part of the both lights
i get scratches out of my caravan widows by using t cut then wax  will this work
or can you replace the the plastic light cover
Broomies Mate
QuoteHi my corsa head lights look like thay are crazed on the top part of the both lights
T-Cut will work, but will be a good 15 minutes per side of constant rubbing, re-applying, rubbing, re-applying etc etc.
Use something slightly more abrasive, such as Farecla G3 or any other brand cutting compound, but dont go over the top.  Finish with T-Cut.  Ideally use a Mop with a Medium Density head, but be gentle.
