Author Topic: Translating those Haynes shop manuals lol  (Read 1477 times)
Alien Performance
  • dumbarton scotland
« on: 23 July 2010, 02:21:06 »
Haynes: This is a snug fit.
 Translation: You will skin your knuckles!
Haynes: Rotate anticlockwise.
 Translation: Clamp with vice grips then beat repeatedly with hammer, anticlockwise
Haynes: This is a tight fit.
 Translation: Not a hope in hell matey!
Haynes: As described in Chapter 7...
 Translation: That'll teach you not to read through before you start, now you are looking at scary photos of the inside of a gearbox.
Haynes: Pry...
 Translation: Hammer a screwdriver into...
Haynes: Undo...
 Translation: Go buy a tin of WD40 (catering size).
Haynes: Retain tiny spring...
 Translation: "Jeez what was that, it nearly had my eye out"!
Haynes: Press and rotate to remove bulb...
 Translation: OK - that's the glass bit off, now fetch some good pliers to dig out the bayonet part.
Haynes: Lightly...
 Translation: Start off lightly and build up till the veins on your forehead are throbbing them re-check the manual because this can not be 'lightly' what you are doing now.
Haynes: Weekly checks...
 Translation: If it isn't broken don't fix it!
Haynes: Routine maintenance...
 Translation: If it isn't broken... it's about to be!
Haynes: One spanner rating.
 Translation: Your Mum could do this... so how did you manage to botch it up?
Haynes: Two spanner rating.
 Translation: Now you may think that you can do this because two is a low, tiny, 'ikkle number... but you also thought the wiring diagram was a map of the Tokyo underground (in fact that would have been more use to you).
Haynes: Three spanner rating.
 Translation: But Nova's are easy to maintain right... right? So you think three Nova spanners has got to be like a 'regular car' two spanner job.
Haynes: Four spanner rating.
 Translation: You are seriously considering this aren't you, you plebe!
Haynes: Five spanner rating.
 Translation: OK - but don't expect us to ride in it afterwards!!!
Haynes: If not, you can fabricate your own special tool like this...
 Translation: Hahahahahahahahahahahahahahahahahahahahahahaha!!!!
Haynes: Compress...
 Translation: Squeeze with all your might, jump up and down on, swear at,  throw at the garage wall, then search in the dark corner of the garage for whilst muttering "bugger" repeatedly under your breath.
Haynes: Inspect...
 Translation: Squint at really hard and pretend you know what you are looking at, then declare in a loud knowing voice to your wife "Yep, as I  thought, it's going to need a new one"!
Haynes: Carefully...
 Translation: You are about to cut yourself!
Haynes: Retaining nut...
 Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
 Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Turning the engine will be easier with the spark pugs removed.
 Translation: However, starting the engine afterwards will be much  harder. Once that sinking pit of your stomach feeling has subsided, you can start to feel deeply ashamed as you gingerly refit the spark plugs.
Haynes: Refitting is the reverse sequence to removal.
 Translation: But you swear in different places.
Haynes: Prise away plastic locating pegs...
 Translation: Snap off...
Haynes: Using a suitable drift...
 Translation: The biggest nail in your tool box isn't a suitable drift!
Haynes: Everyday toolkit
 Translation: Ensure you have an RAC Card & Mobile Phone
Haynes: Apply moderate heat...
 Translation: Placing your mouth near it and huffing isn't moderate heat.
Haynes: Index
 Translation: List of all the things in the book bar the thing you want to do!
For Added Haynes Fun:
 Go to the first section, Safety First, and read the bit about Hydrofluoric Acid - do you really want the advice of a book that uses this form of understatement???!!?
Now look at the lovely colour section on body repairs - as you look at these two pages say to yourself over and over until it sinks in "mine will  never look like that..."
Flick to the end and look at the colour glow plug pictures, how do these compare to the glow plugs in your omega? If you cannot locate the glow plugs in your omega see the last translation on the list!
 NB: Haynes Manuals are (c)opyright of a very disturbed sadist
  ;D
« Last Edit: 23 July 2010, 02:27:20 by Alien_Performance »
Re: Translating those Haynes shop manuals lol
« Reply #1 on: 24 July 2010, 04:57:15 »
not forgetting the fabled saying, 'refering to chapter 2 remove engine...'
vvfunny, and so nearly true. ;D ;D ;D ;D ;D ;D ;D :y
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
« Reply #2 on: 25 July 2010, 18:57:58 »
very good ;D
dieseldonicely
